Author Topic: Negative battery cable location on 68 BB with AC  (Read 6980 times)
68ashgoldRS/SS
« on: November 24, 2009, 07:32:41 PM »
Hello,  Can anyone tell me where the ground connections should be for the negative cable on a 68 396 car with AC?  I could not find it in the AIM, but maybe I've just overlooked it?    Thanks in advance for your help!
Ed Denney from South Jordan Utah
1968 Camaro RS/SS -Restored
1959 Chevrolet Corvette Restomod-Project in progress
1956 Dodge D100 Pickup -Project
1936 US Soldier, Dad -Best Friend
Re: Negative battery cable location on 68 BB with AC
« Reply #1 on: November 24, 2009, 07:55:14 PM »
Check UPC C60 sheet E2 (page 218). It goes to the lower passenger side compressor mount.
68ashgoldRS/SS
« Reply #2 on: November 24, 2009, 08:09:31 PM »
Great!  Does it happen to show where the smaller pigtail connects as well?   I'll recheck the AIM tonight.  Thank you!
« Reply #3 on: November 24, 2009, 08:20:56 PM »
No, but it states "Balance of asm is same as reg. prod." which is shown on UPC 12 sheet A4 (attached to the fender reinforcement)
Also note that the picture on UPC C60 sheet E2 is for the L6 engines, so the negative and positive terminals are backwards from the V8 engines.
68ashgoldRS/SS
« Reply #4 on: November 24, 2009, 09:23:30 PM »
Thanks again Ed.  Appreciate your help as always.
big iron
« Reply #5 on: November 19, 2010, 02:59:52 AM »
The sheet shows that a production washer was used. That is interesting, as most grounds have a toothed lock washer.
I wonder if that is a misprint, as 12 A5 shows grounds with toothed lock washers.
Anyone with an original 68 BB w/AC ?
Bob
« Reply #6 on: November 19, 2010, 04:38:23 PM »
"Production washer" means the same washer used on the negative cable on base cars, which was a toothed lock washer; there's no mis-print.
big iron
« Reply #7 on: November 20, 2010, 12:46:44 AM »
JohnZ,
Thanks for the clarification.
Bob
