Author Topic: window crank  (Read 8727 times)
cabinrange
window crank
« on: November 23, 2009, 01:05:34 AM »
   I hope someone can help me.
   I have a 1968 Camaro that I bought from the original owner in 1976. It was ordered with RPO-730 parchment/black deluxe interior.
   The window cranks have chrome metal knobs. The pattern on the knob matches that of the pattern on the base of the crank arm: and the knob is riveted on.
   The window crank arm is stamped #5719477.
    I have always assumed they were aftermarket knobs riveted on to GM cranks.
    My question is - Did GM ever offer on '68 Camaros (or any other of their models prior to 1976) window cranks with chrome metal knobs? Or did I assume correctly?
    Thanx
GaryL
  • Marilyn and me
Re: window crank
« Reply #1 on: November 25, 2009, 04:43:39 PM »
Are they the metal knob that the plastic fits over?
Gary
Re: window crank
« Reply #2 on: November 25, 2009, 05:30:02 PM »
That number was used for 68, but those same basic handles were used on various Chevrolet models from 1959 through the mid 70's. Starting with the 1967 model year, the metal knobs were covered in plastic. However, the knobs themselves were still basically the same, so I would bet someone just cut the plastic off yours or replaced them with earlier model handles.
HERE'S what they should look like, and HERE'S what they look like for the earlier years. Same part, just without the plastic on the knobs.
Jerry@CHP
Re: window crank
« Reply #3 on: November 27, 2009, 02:20:54 AM »
Window crank handles were color coded to the interior in '67 (unique knobs)  and '68 and clear on the '69 models.
Jerry
cabinrange
Re: window crank
« Reply #4 on: November 29, 2009, 06:30:11 PM »
    I believe Ed has nailed it.
   That would explain the number matching cranks.
    I didn't know GM just upgraded them by overlaying existing cranks with plastic covers.
    And according to Jerry; I would need pearl/parchment plastic knobs to be factory correct.
    Too bad.....I can't find that color anywhere. NOS or repop!
    Thanx guys
RS3SDL2MG
  • Brad
Re: window crank
« Reply #5 on: December 05, 2009, 01:10:35 AM »
those ARE NOT 1968 crank's they are 1967 and previous , the chrome knob's are 1966 and earlier , those are not even close to what 1968 up crank's look like ,
THE 67 plastic knob's were totally different from those chrome one's , they DID NOT put plastic over chrome the 67 plastic knob's are unique to the 1967 model year ,
the parchment knob's are out there but are rare , they pop up on ebay all the time ,
also they are now reproduced and might I say VERY WELL REPRODUCED ! for the 1967 model's ,
but they are not cheap , if you want 5719477 crank's with parchment knob's get your credit card out and here they are $39.99 each ! , but these ARE NOT CORRECT FOR 68 up ,
http://www.ecklers.com/product.asp?pf_id=51999&dept_id=1666#
1967 RS 327 (210) horse C-C ermine white 732 bright blue interior RARE 4P - DELETE
RS3SDL2MG
  • Brad
Re: window crank
« Reply #6 on: December 05, 2009, 01:18:43 AM »
if you want to put your 1968 camaro parchment interior back to the way it came from the factory all the part's are available to do so
#1 order a set of correct 1968 crank's $13.99 each
http://www.rickscamaros.com/product.asp?pf%5Fid=IN%2D181&dept%5Fid=3393
#2 order a set of the parchment knob's $7.99 per pair ( I DON'T KNOW WHY THEY DON'T SELL 68 UP WITH COLORED KNOBS)
http://www.rickscamaros.com/product.asp?pf%5Fid=IN%2D74&dept%5Fid=3393
plumL78
Re: window crank
« Reply #7 on: December 07, 2009, 11:40:25 PM »
Here are some 67s and 68s
cabinrange
Re: window crank
« Reply #8 on: December 08, 2009, 09:51:23 PM »
  How's that for response?
   Thanx everyone.
