Author Topic: 68 z28 correct starter #S  (Read 5616 times)
jonboy1216
« on: November 21, 2009, 03:14:33 AM »
ive have seen alot of posts about this subject but im still confused is the 1108367 the correct # for a 68 z and should it have the short solenoid or the high torque one with the copper spacer?
Re: 68 z28 correct starter #S
« Reply #1 on: November 21, 2009, 04:40:29 AM »
Here's some information on the subject...  http://www.camaros.org/forum/index.php?topic=1613.0
jonboy1216
« Reply #2 on: November 21, 2009, 03:32:22 PM »
thanks for the 1st part of the question. but is the stater a high torque solenoid with the copper spacer or not?
Marty
« Reply #3 on: November 21, 2009, 05:35:35 PM »
I have a 1108367 starter in the garage and it has the long solenoid on it, stamped 1114344. I bought it at a swap meet so I'm not sure what it was originally out of.
Martin
Martin Foltz
CRG Member
68 Van Nuys Camaro
« Reply #4 on: November 21, 2009, 06:27:04 PM »
I can't remember if this is my original solenoid or not, it's 1114356.  What do you mean by copper spacer?
« Reply #5 on: November 22, 2009, 01:48:54 AM »
Because the H.T. starter housing is longer the solenoid requires a spacer at the front mounting point (where the terminals are).
« Reply #6 on: November 22, 2009, 07:58:50 PM »
The Z starter was the same as the 327/210hp starter. There wasn't anything high torque about it. They did the same thing with the battery - the Z used the smaller Y55 battery.
It looks like they had some rules about how much cubic displacement was required before the component was 'upsized' - and they didn't account for compression ratio.
That said, the starter and battery for the Z are not known problem areas, so their methodology seemed to have worked.
