Author Topic: LAST PRODUCTION 302  (Read 10429 times)
DONCZ28
LAST PRODUCTION 302
« on: November 11, 2009, 01:07:50 AM »
HAVE A 69 302 STAMPED V1024 DZ, (OCT 24TH, 1969) ARE THERE ANY LATER?
Jerry@CHP
Re: LAST PRODUCTION 302
« Reply #1 on: November 11, 2009, 01:26:35 AM »
Can we see the stamping?
Jerry
DONCZ28
« Reply #2 on: November 11, 2009, 01:55:15 AM »
JERRY,I  LIVE IN MANCHESTER MD., AND I BELIEVE YOU LIVE CLOSE TO WESTMINSTER, I AM GOOD FRIENDS WITH BRIAN TILLES OF CORV ETTE  SPEC. OF MD. AND HAVE WORKED FOR HIM.  I HAVE  OWNED THIS  MOTOR SINCE 1982. I FOUND IT THROUGH AN ADD POSTED IN 1982  @ EASTERN SPEED CENTER .I BOUGHT THE  COMPLETE SHORT BLOCK FOR $225. THE CAR WAS TOTALED IN  72, AND HAD 18,000 MILES.  THE SELLER USED THE HEADS, INTAKE, TRANEY ETC. THE CAR SAT IN A MD. JUNK YARD FOR 10 YEARS AND THE OUTSIDE OF THE MOTOR HAD  SURFACE RUST AND PITTING. THE  BOSS IS PITTED BUT THE NUMBERS ARE LEGIBLE,. THE ENGINE INTERNALLY WAS IN EXCELLENT SHAPE AND IS NOW REBUILT WITH A STANDARD BORE.  I PURCHASED THIS MOTOR FOR MY 69 Z ,WHICH LACKED IT'S ORIGINAL MOTOR .....DON
« Reply #3 on: November 11, 2009, 03:32:06 AM »
1024 is one of the last dates observed. I've seen one later date.
Did it have the original distributor?
DONCZ28
« Reply #4 on: November 11, 2009, 09:21:28 PM »
NO DISTRIBUTOR.   I  DID WRITE DOWN THE VIN NUMBER, BEFORE I PAINTED THE BLOCK. "BY THE OIL FILTER". THIS INFO. IS NOW PACKED AWAY FOR MOVING, BUT I CAN SUPPLY IT AT A LATER DATE. THE BLOCK IS AN 010 CASTING. I ALSO REMEMBER THE MAIN BEARINGS BEING DATE CODED WHEN I TOOK THE MOTOR APART...........DON
Jerry@CHP
« Reply #5 on: November 12, 2009, 02:38:10 AM »
Don,
The latest I have is 1022, we'll have to hook up so I can get some photos of the block stamp.  Or, when ever you can shoot some nice clear photos.  Should run the vin at the MVA to find original selling dealer.
Jerry
DONCZ28
« Reply #6 on: November 12, 2009, 04:33:23 AM »
JERRY,  YOU CAN CONTACT ME  #443-677-1617.......OR DONALD_ CAVEY@BD.COM.....THANK'S................DON
« Reply #7 on: November 12, 2009, 05:30:41 AM »
I'd also be interested in a pic of the pad. No hurry. :)
DONCZ28
« Reply #8 on: November 12, 2009, 11:00:17 PM »
FOUND VIN # FOR DZ MOTOR WITH 10 /24/09  BUILD DATE  (9N7105XX).......DON
L78 steve
« Reply #9 on: November 13, 2009, 05:03:45 PM »
Don,
Jerry
  How is this done???
69 Z/28 Dover White. SOLD
Jerry@CHP
« Reply #10 on: November 14, 2009, 04:37:40 PM »
Contact the MVA in Glen Burnie, MD.  All records available and cost is about $8 per title owner back to the MSO.  Good docs from the state of Maryland.  That's about the only thing this state is good for!
Jerry
hotz
« Reply #11 on: November 16, 2009, 01:20:51 AM »
Could I also call the state of Idaho to get the info on my car? this would just give me the info of what dealer sold the car right? where can you find other info besides previous owners? Thanks and hope I am not side tracking you Don.
68rs327conv
    • The build
« Reply #12 on: November 17, 2009, 11:38:34 AM »
Go to Glen Burnie, Title/File Room, at first they may refuse due to privacy laws but tell them you are not interested in personal information and it can be hidden with a sharpie and they will print all past titles from microfilm. You can see info when held up to a light or you might get lucky as in my case because they had a problem with the film and agreed to mail my title info and them forgot to black out the personal information.  I was able to locate the original owner as well as discover Pat Goss from Motorweek fame own the vehicle at one point.
Good luck
68 RS Conv 327/210hp, Powerglide Factory AC
DONCZ28
« Reply #13 on: December 03, 2009, 03:57:05 AM »
RAN   VIN #  FOR 10/24/69  BUILT   302   WITH   MD.  DMV   WITH   NO   RESULT...........DON
