Author Topic: 3932472 intake couppla Q's ? ?  (Read 5719 times)
opelitis1
« on: November 05, 2009, 07:36:30 PM »
Anybody have a pic(s) of the front of this intake - specifically in the thermostat area..  I have 2 studs coming outta the intake where the thermostat would bolt on and, I am not sure they are what came outta GM in '69??  Also, second part of the query is, what thermostat housing is correct numbers-wise, for this intake??
Thank You!!
Ted
Re: 3932472 intake couppla Q's ? ?
« Reply #1 on: November 06, 2009, 12:28:30 AM »
This is an over the counter, but is the same.
« Reply #2 on: November 06, 2009, 12:28:53 AM »
opelitis1
« Reply #3 on: November 06, 2009, 01:58:35 PM »
When the #472 intake came on the 1969 302ci engine, were there not 2 different sized studs that were used to retain the 387660 thermostat housing, with the psgr side stud  being used to catch the alternator bracket??   Just got my intake back and I am trying to remember if I had bought it that way or was Bubba hard at it??
Thanks!!
Ted
« Reply #4 on: November 06, 2009, 03:49:17 PM »
The 302 thermostat housing (660 aluminum) was attached by a bolt with a threaded stud extension on the passenger side where the upper alternator bracket was attached with a nut, and by a bolt on the driver's side.
opelitis1
« Reply #5 on: November 06, 2009, 09:30:52 PM »
Thanks John!!  Exactly what I was after..
Ted
