Author Topic: Restoring Inside Raer View Mirror  (Read 27317 times)
MyRed67
  • SZZLN 67
« on: October 19, 2009, 02:17:11 AM »
   I have seen some "restored" Inside rear view mirrors for Sale.   They talk about the Glass being "resilvered", does anyone here know of a place that does this service?   My original mirror is in good shape, except for the plating.  Thanks!
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
Re: Restoring Inside Raer View Mirror
« Reply #1 on: October 19, 2009, 04:54:59 PM »
Try Paragon - they've been restoring mirrors for decades.
Jerry@CHP
« Reply #2 on: October 21, 2009, 10:27:00 AM »
Restore your original.  They are stamped "USA" on the bottom and the repros are not.  Points deducted for repro mirrors.
Jerry
MyRed67
  • SZZLN 67
« Reply #3 on: October 26, 2009, 07:19:46 PM »
  Thanks for the info. Guys!   I got hold of Paragon, they only stocked the Glass for '67 'Vette, but I took the chance that they were the same.  They are the same, I recieved the glass today, it's in and looks GREAT !   Just wanted to Thank you guys that helped.
1967 Camaro  LOS  11A
KevinW
« Reply #4 on: October 27, 2009, 11:09:00 AM »
That sounds great, but how did you replace the glass in the housing?
MyRed67
  • SZZLN 67
« Reply #5 on: October 29, 2009, 04:52:57 AM »
   The original Gray rubber or vinyl, whatever it is cleaned up nice, I left it in.
1967 Camaro  LOS  11A
GaryL
  • Marilyn and me
« Reply #6 on: October 29, 2009, 10:00:59 PM »
How do you get the glass into the "rubber" trim. Seems like it is a little too stiff.
Gary
gro51
  • 68 SS/RS 350
« Reply #7 on: October 29, 2009, 10:32:25 PM »
I tried to get the rubber trim off mine but I couldn't.  I didn't want to break it.  It's not as pliable as when it was new.  So I've just left my original mirror alone, even though it needs to be re-silvered.
Joe
Schodack, NY
'68 SS/RS 350, M21, 3:73, Rallye Green, Black Deluxe Interior
MyRed67
  • SZZLN 67
« Reply #8 on: October 31, 2009, 05:07:28 AM »
  Mine was still pretty pliable.  I ran a small flat screwdriver around the edge of the glass.  VERY CAREFULLY.  I started across the bottom and worked my way up the sides. There is only a small lip there.  Once you are most of the way up the sides, you will be able to just pull the top out. I didn't try to take the Gray rubber out of the housing.  I never found a way to do that, and in the end, I didn't have to.  To put it back together I just did the reverse, using a Popsickle stick so as not to scratch the Glass.  I am attaching a photo of finished project.(Not the best color)
1967 Camaro  LOS  11A
« Reply #9 on: October 31, 2009, 05:48:31 PM »
Put it in hot water to soften prior to removal.
MyRed67
  • SZZLN 67
« Reply #10 on: July 14, 2010, 04:09:41 AM »
 It seems that the Forum lost some pictures when it was down.  If anyone wants to see that pic. send me an e-mail.
1967 Camaro  LOS  11A
MyRed67
  • SZZLN 67
« Reply #11 on: July 15, 2010, 07:15:48 AM »
  I was asked to repost these pics. so here goes.  Note the GLARE PROOF on top, and the MADE IN    USA on the bottom.  These stamps are not on the repros.
1967 Camaro  LOS  11A
big iron
« Reply #12 on: July 15, 2010, 01:21:07 PM »
Do all mirrors have the gray trim or are they color coordinated to the interior?
Thanks for the pictures.
Bob
Kelley W King
« Reply #13 on: July 15, 2010, 03:29:45 PM »
They are all gray.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
big iron
« Reply #14 on: July 15, 2010, 04:09:54 PM »
Thanks for the reply.
Bob
They are all gray.
