Author Topic: 67 Kick Panel Vents  (Read 4249 times)
GSD5
    • 1967 Camaro SS/RS Convertible
67 Kick Panel Vents
« on: October 18, 2009, 03:10:13 PM »
Does anyone know if it is possible to replace the rod that activates the vent in the kick panel (non-AC car) of a '67? If so, any suggestions on the procedure would be greatly appreciated! I found a set of otherwise excellent originals to replace the beat up ones that I have now but one of the rods is broken off at the point where it starts to extend into the recessed area that the handle is in. There is a metal clip on the back side that seems to resiist removal, and I'm afraid that forcing it will cause the plastic to snap.
Thanks!
67RS/SS Convertible
Re: 67 Kick Panel Vents
« Reply #1 on: October 18, 2009, 07:37:56 PM »
Piece of cake. Pull that clip and remove the assembly. Spray a little help on it if you have to; I never did. They are snug and seem a worthy adversary. You will find the loop at the end of the cable will require persuasion to pass through the hole. I've done a few. Kicks are pretty resiliant to "snapping" as you say but use caution nonetheless. Lube that sleeve assy well.
GSD5
« Reply #2 on: October 18, 2009, 08:20:47 PM »
Thanks...I'll give it a whack, and thanks also for the comprehensive nature of the info!
67RS/SS Convertible
