Author Topic: Front Calipers  (Read 12495 times)
z28302dz
Front Calipers
« on: September 30, 2009, 11:51:28 PM »
What is the correct part number for Front Calipers on a 69 Z/28, and also what date coding method is used?  Build date is the first week of March.
Thank you.
Re: Front Calipers
« Reply #1 on: October 01, 2009, 12:40:52 AM »
What is the correct part number for Front Calipers on a 69 Z/28?
My '69 Chevrolet P&A lists the R/F brake caliper assembly as part #5469123 and the L/F brake caliper assembly as part #5469122.
z28302dz
Re: Front Calipers
« Reply #2 on: October 06, 2009, 12:13:52 AM »
Thanks Paul.  Anything on date coding?
Re: Front Calipers
« Reply #3 on: October 06, 2009, 12:47:14 AM »
Sure, read this CRG thread...    http://www.camaros.org/forum/index.php?topic=2792.0
Mark
Re: Front Calipers
« Reply #4 on: October 06, 2009, 04:10:44 PM »
Keep in mind the service part number of an item can, and usually is, different than the production part number, and the casting number on a component is almost always different than either part number.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
z28302dz
Re: Front Calipers
« Reply #5 on: October 07, 2009, 06:41:02 PM »
Does anyone which casting numbers may have been used for the 69' model year?
Thanks again.
sixt9x33rs
Re: Front Calipers
« Reply #6 on: October 11, 2009, 10:13:46 PM »
My original calipers are:
Right front part number 5463633
Left front part number 5463833
I did not look for a date code when I wrote those numbers down 4 years ago.
camaro cat
Re: Front Calipers
« Reply #7 on: October 12, 2009, 12:33:05 AM »
Are you sure that's right? I looked at mine and they are both cast 5463633. In looking at them they are the same casting, just machined differently.  I noticed that on both, the first 3 digits "546" are the same size. On one the number 3 in the 4 spot is a much larger font that any of  the other number's, but on the other caliper it is the same size as the first 3. On both, the last 3 digits "633" are larger font than the first 3 or 4. The caliper machined for the passenger side which has the large 3 has a casting date of 20 while the other side has a date of 345. They go on a 02D car. This may be the craziest bit of detail I have ever posted about but to much is better than not enough.
Loren
Loren
1967 RS L30 10C LOS
1969 SS/RS L78 02D NOR
sixt9x33rs
Re: Front Calipers
« Reply #8 on: October 12, 2009, 01:35:47 AM »
No, I could have the 6 mistaken for an 8? When I took the numbers off the calipers it was before I cleaned them up and repainted them.
camaro cat
Re: Front Calipers
« Reply #9 on: October 12, 2009, 01:56:58 AM »
I understand. I was afraid I had done the same thing and had to go back and recheck. That's when I went crazy and noticed the different styles of font on the numerals.
Loren
Loren
1967 RS L30 10C LOS
sftibbs
Re: Front Calipers
« Reply #10 on: October 14, 2009, 10:16:56 PM »
The casting numbers on mine are the same as Loren's, except the casting dates are 305, and on the other, 292.
What was the original color of the calipers?
'69 SS350
sixt9x33rs
Re: Front Calipers
« Reply #11 on: October 17, 2009, 01:57:41 AM »
Black, mine also had paint dabs or inspection marks on them. Both calipers had orange paint dabs on them.
