Author Topic: loosening the power steering pump  (Read 5337 times)
my124677n
« on: September 28, 2009, 12:28:01 AM »
This should be an easy one, but on my '67 small block with power steering (no a/c), I loosened the one bolt on the power steering pump (within the slide area) which I thought would allow me to push the pump toward the center of the engine (so that I could remove the belt), but it will only budge a small amount. Still too much tension to remove the belt. Any other bolts that need to be removed or loosened.  Thanks.
Re: loosening the power steering pump
« Reply #1 on: September 28, 2009, 03:06:26 AM »
You also need to loosen the bolt that the p/s pump pivots on.
sixt9x33rs
« Reply #2 on: October 18, 2009, 01:43:53 AM »
If you dont have one you may want to buy yourself a Chasis Service Manual and also a Assembly Instruction Manual. Not trying to be a smart a. These manuals are a great help.
Have fun!
Oregonjam
  • 68 ss350
« Reply #3 on: October 19, 2009, 05:45:13 PM »
Just a tip for re-installation.
I use a strap wrench to help get a grip on the pump when tightening the belt when I am by myself. It won't scratch the housing. I have seen a lot of the pumps bashed in on one side from someone using a pry bar. This works well on the 1st gen small blocks.
68 07D SS350
John
