Author Topic: 68 4spd xmsn shifter  (Read 5253 times)
joesauer
« on: September 26, 2009, 04:00:13 PM »
My 68 SS has an older muncie m21 4spd (casting 3851325).  Has the speedo cable on the left side & appears to be out of a 1963-65 chevy/nova/etc.  Since it was just rebuilt (over $1900), I'm not ready to replace it with a numbers matching xmsn(yet).  I'd like to change the linkage/shifter to the correct 68 muncie. Does anyone know if the 68 linkage/shifter will work ok?  Thanks
acelr8
Re: 68 4spd xmsn shifter
« Reply #1 on: September 26, 2009, 09:53:03 PM »
Change the tail housing(to a right side speedo),move the drive gear(don't forget) and go.No problem.Jeff
L30M20
« Reply #2 on: October 25, 2009, 05:35:32 AM »
My L30M20 has a 4spd shifter, wide ratio on a saginaw trans. The shifter has become very loose, I dont want to have to take the cross bar off to check it out . I can't find any diagrams to give me an idea whats broke,missing. Any ideas or similar problem! Carl
joesauer
« Reply #3 on: October 25, 2009, 03:44:06 PM »
Still looking for help re: using 68 Muncie shifter/linkage on an older Muncie 4speed with speedo cable on the left side (see previous post).  Does anyone know if it will work ok, without changing out the tailshaft to a later Muncie.  My 68 SS xmsn was recently rebuilt, so don't want to change it out to a correct numbers matching unit (yet).  Thanks.
