Author Topic: 69 z manual steering gasket cover install  (Read 6001 times)
sixt9x33rs
« on: September 11, 2009, 10:45:27 AM »
Can someone give me a few tips about the install of the above gasket? Is there more to it than removing the three screws that hold the cover on? I am a bit inimidated by the center adjusting screw.
m22mike
Re: 69 z manual steering gasket cover install
« Reply #1 on: September 11, 2009, 12:09:06 PM »
The adjusting bolt is threaded to the cap. You will need to  "un screw" the cover by turning the adjuster. Go easy and do not beat on it with a hammer, you may need to loosed the cap with a very this putty knife if the old gasket is stuck.
 Re adjust box when done.
 Good luck Mike
sixt9x33rs
« Reply #2 on: September 11, 2009, 03:19:09 PM »
 Good luck Mike
How do you re adjust the box? Would this procedure be loacted in the Chasis Service manual?
« Reply #3 on: September 11, 2009, 05:12:55 PM »
Yes, see Section 9 in the '69 Chassis Service Manual.
sixt9x33rs
« Reply #4 on: September 11, 2009, 10:30:21 PM »
thank you
