Author Topic: 69 z28 clutch pedal adjustment?  (Read 8353 times)
jon69
« on: September 08, 2009, 01:49:51 PM »
Is there some way of adjusting the clutch pedal height? maybe this is normal but the clutch pedal is alot closer to the driver than the brake pedal. aren't the clutch and brake pedal supposed to be somewhat even?
Thanks, Jon
Gramps69Z
  • 69 X33 D80
Re: 69 z28 clutch pedal adjustment?
« Reply #1 on: September 08, 2009, 09:43:49 PM »
My clutch pedal is higher than the brake.
« Last Edit: September 08, 2009, 10:38:29 PM by WYKOFF69Z »
Captain John Wykoff
69Zlemansblue
« Reply #2 on: September 09, 2009, 03:52:03 AM »
That is correct to have the clutch pedal higher, it should rest on the rubber clutch stop.
Rich
69 Z/28 X33 D80 M20
DZ 302  373 rear gears
Norwood-late Sept. 69
Owned since 1979
« Reply #3 on: September 09, 2009, 04:11:41 PM »
The clutch return spring should hold the clutch pedal up against the rubber bumper on the pedal support (Assembly Manual, UPC 7, sheet C2, item #9), then adjust the lower fork pushrod to get 1" to 1-1/2" of pedal free play between the full-up position (against the bumper) and the point where you feel resistance when depressing the pedal (throwout bearing contacting the clutch fingers).
