Author Topic: VIN Number Help  (Read 14592 times)
airart1
VIN Number Help
« on: August 28, 2009, 03:58:48 PM »
Can you help me decode the following VIN Number?
12437KC100126
Oregonjam
  • 68 ss350
Re: VIN Number Help
« Reply #1 on: August 29, 2009, 02:53:00 AM »
That appears to not be a valid VIN for any vehicle I have ever seen.
Can you post a photo and make/model it is on. It is not a GM VIN I am familiar with at all.
A VIN when decoded for a 1st gen Camaro will only tell you the following
6 or 8 cylinder, Coupe or Convert, year of manufacture, Assembly plant, and serial number
The trim Tag would help you decode factory installed options...
68 07D SS350
John
Re: VIN Number Help
« Reply #2 on: August 29, 2009, 03:07:12 AM »
12437KC100126
Are you in Venezuela? Can you post a photo of the VIN plate and cowl tag?
airart1
Re: VIN Number Help
« Reply #3 on: August 29, 2009, 03:51:14 AM »
This car is in the United States. The speedometer is in kilometers. I am helping a friend research this car. i will get the photos this weekend and post them.
BlackoutSteve
Re: VIN Number Help
« Reply #4 on: August 29, 2009, 06:11:12 AM »
Pictures of the speedo too please!
Restoring my RHD 69 Jane in Melbourne, Australia.
http://www.usmuscle.com.au/Forum/showthread.php?t=2840
airart1
Re: VIN Number Help
« Reply #5 on: August 29, 2009, 02:31:52 PM »
I cannot get the pictures to load in this format. Please go to - www.drop.io/69RSCamaro - to view the pictures of the cowl tag and the speedometer.
airart1
Re: VIN Number Help
« Reply #6 on: August 29, 2009, 05:43:02 PM »
I had the owner look at the VIN number and it is the same as the cowl tag.
BlackoutSteve
Re: VIN Number Help
« Reply #7 on: August 29, 2009, 10:39:35 PM »
Just one pic shows, and that's of the tag.. Gee, I never seen one like that before..
airart1
Re: VIN Number Help
« Reply #8 on: August 29, 2009, 10:53:13 PM »
I reposted the picture of speedometer at www.drop.io/69rscamaro.
Re: VIN Number Help
« Reply #9 on: August 30, 2009, 01:21:27 AM »
Can you post a photo of the VIN plate so we have both it and the cowl tag? The car may have been built in Venezuela, and the VIN plate could verify that.
airart1
Re: VIN Number Help
« Reply #10 on: August 30, 2009, 01:57:45 AM »
He says that the VIN number and the Cowl tag have the same number. We are also thinking that it is from Venezuela. Is taht what the KC means?
Re: VIN Number Help
« Reply #11 on: August 30, 2009, 04:49:13 AM »
12437KC100126
12437 is the body type = Coupe
K is the year = 1970
C is the assembly plant = Caracas (Venezuela)
100126 is the sequence number
A rare car indeed!  Does the car have it's original engine?  If yes, can you post a picture of the engine pad?
airart1
Re: VIN Number Help
« Reply #12 on: August 30, 2009, 05:01:36 AM »
I believe that this car is a 69. Does the K still stand for 1970. Where did you find this info on KC? There a lot of folks on the net looking for this kind of info. I saw another post in another forum and they had a JC code.
airart1
Re: VIN Number Help
« Reply #13 on: August 30, 2009, 07:05:53 PM »
I have verified that the engine numbers match. I have posted more pictures at www.drop.io/69rscamaro
We will get the cowl vent removed shortly and take alook for any other stampings there. If I am guessing right, the K is for the 10th month which makes this car one of the late 1969's produced due to the extened production schedule while they were fixing the metal stamping problems on the 1970 cars. Any or help or questions would be appreciated.
Re: VIN Number Help
« Reply #14 on: August 31, 2009, 04:56:34 AM »
Correct me if I'm wrong, but isn't the year code on the first generation Caracas Camaros is as follows...
G = 1967
H = 1968
J = 1969
K = 1970
The letter "I" was not used because of it's similarity to the number "1".
The person on this forum who could tell you the most about the Caracas Camaros is "KurtS".
