Poll
Which of the options would be preffered on a 1968 Column Auto?
Install Guages with black after market bracket under ash tray
2 (40%)
Install 1967 wood grain guage bracket with guages under ash tray
1 (20%)
Keep original with no guages (dummy lights only)
2 (40%)
Total Members Voted: 5
Voting closed: September 27, 2009, 01:53:40 PM
Author Topic: Aftermarket Guages in 68 Auto  (Read 10094 times)
Oregonjam
  • 68 ss350
« on: August 28, 2009, 01:53:40 PM »
This is for a 1968 SS350 with auto column shift, no guages and the wood grain finish on instrument panel. Suggestions welcome.
68 07D SS350
John
hotrod68
  • almost finished
Re: Aftermarket Guages in 68 Auto
« Reply #1 on: August 29, 2009, 03:28:57 AM »
I like the way Yenko did it--a single chrome panel below the ashtray with oil, amp, and temp gauges. It's simple and the gauges are easily readable. My 2 cents.
tom
    • Discount Internet Services
« Reply #2 on: August 30, 2009, 09:36:45 PM »
Not sure what was in a 68 firebird, 69 firebird had a set of quad guages in the dash where a tach would normally go. I like the set, it might work in a 68 Camaro dash. Verify first.
69 X11 Z21 L14 glide
o
lakeholme
  • 68-12D L30/M35
« Reply #3 on: September 02, 2009, 12:48:20 PM »
John,
Beyond originality, am I correct that your ash tray is woodgrain with an 07D build?
The continuity would help the "look"...
Oregonjam
  • 68 ss350
« Reply #4 on: September 02, 2009, 06:08:16 PM »
Yes, the center dash area is wood grain and all of the interior is a stock appearance. I do currently run Oil and Water temp guages on a black after market bracket using existing screws under the ashtray. I debated taking them out but am feeling uneasy about not having them for long hauls etc. I was also thinking that the continuity offered by the 67 insruments would be nice and appear stock to those that don't know. I think they will blend more with the deisgners intent of what the interior should be like. Although the feature was not on this Camaro I am considering adding it. The black bracket says to all that this is an after market addon and stands out.
I do go back and forth on it...
68 07D SS350
John
lakeholme
  • 68-12D L30/M35
« Reply #5 on: September 02, 2009, 09:28:20 PM »
John,
Not sure I made my point clear:  I guess I would vote for your second option above, a woodgrain bracket, because it would be a consistent look with your 07D build.  My 68 12D build has the original black ashtray with the woodgrain panel.  (Beyond that, it has a console, so if I ever add guages, my choice is simple.)
Read through this thread (if you haven't already):
http://www.camaros.org/forum/index.php?topic=1534.0;all
I know what you mean about going back and forth on the decision...
lakeholme
  • 68-12D L30/M35
« Reply #6 on: September 03, 2009, 12:55:15 PM »
Got your PM.
From Ed and others observations in that thread, your ash tray should be woodgrain.  It's first quarter 68 build dates that may go either way.
Oregonjam
  • 68 ss350
« Reply #7 on: September 04, 2009, 01:56:23 PM »
Thanks phillip. I did not realize that black ash trays were used with the wood grain center dash sections early on. Thanks again for the thread and feed back.
68 07D SS350
John
