Author Topic: pointers for new hinges  (Read 6235 times)
william1
« on: August 21, 2009, 02:04:08 PM »
 OK after a search i gonna ask,, any pointers,, short cuts, to lining up camaro doors after installing new hinges.
Re: pointers for new hinges
« Reply #1 on: August 21, 2009, 02:36:53 PM »
Fit them fore-aft to the quarters, and up-down and in-out to the rockers; fore-aft and up-down is at the pillar side, in-out is at the door side. Remove the striker bolts first, fit the doors, then install the strikers last to set in-out at the rear of the door and smooth closing effort.
mark x22
« Reply #2 on: August 21, 2009, 08:44:26 PM »
If the door panels are off you can adjust the striker bolt from inside the door with the door closed through an access hole in the door latch .
« Reply #3 on: August 21, 2009, 11:53:37 PM »
There's tons of information for you on this subject in Section 6 of the 1969 Body by Fisher Service Manual.
william1
« Reply #4 on: August 25, 2009, 12:13:43 PM »
 thanks ,, will try and yes have fisher manuel coming,
