Author Topic: Heat pipe fastener ID needed  (Read 6723 times)
Oregonjam
  • 68 ss350
« on: August 11, 2009, 06:36:02 PM »
Does any one know what the fastener used to hold the stove pipe to the heat stove was?
Application: 1968 sb 350 4 barrel
What finish did the Heat Stove have from the factory?
Thanks for your help.
68 07D SS350
John
BillG
Re: Heat pipe fastener ID needed
« Reply #1 on: August 22, 2009, 01:38:38 AM »
I don't believe there was a fastener.  The stove pipe just fit into the flange.  As for finish, I believe the pipe was 30% gloss black.
Bill Garrett
68rs327conv
    • The build
« Reply #2 on: August 22, 2009, 03:06:19 PM »
See page 345 of 1968 ASM.  Screw part # 447143 was used and I believe AMK Products has it listed on there website.
68 RS Conv 327/210hp, Powerglide Factory AC
Oregonjam
  • 68 ss350
« Reply #3 on: August 26, 2009, 08:38:49 PM »
Thanks Mike,
I saw the part # but could not find a reference to what that is. I will check with AMK as I have not checked with them on this one.
BillG - The Heat Pipe was painted but I am finding that the Heat Stove was bare steel. 68 requirred a screw at the base of the Heat Pipe. 69 did not (at least on Chevelles).
John
68 07D SS350
John
BillG
« Reply #4 on: August 27, 2009, 12:29:20 PM »
Thanks.  I stand corrected.  I was assuming 68-69 were about the same; just opposite sides of the engine.
Bill Garrett
Grsmnkey
« Reply #5 on: August 27, 2009, 06:40:55 PM »
Hi,
I owned an 1968 06c 327/275hp auto.  It still had the pipe and shield, never had a screw in it.  Now I don't know if it was replaced before my family owned it (early 80's) or if it was replaced when it had the engine stop lift cable installed (recall).  I do have another setup from a '68, I don't know the build information, it also has never been screwed together.
Oregonjam
  • 68 ss350
« Reply #6 on: August 28, 2009, 01:41:40 PM »
Can you post a pic? The heat pipe to heat stove on a 350 has a screw but only one on the the bottom. Nothing located on the top side. The iformation I have learned so far is that the 2 barrel carb setup also requirred a different heat pipe than the 4 barrel but utilized the same aircleaner base and heat stove. I never saw one of those so if you have one a pic would help identify it.
68 07D SS350
John
