Voltage Reg is a new Delco Remy. It appears to be grounded. All terminals filled on VR and Horn Buss below it.
My junction block (new) has nothing mounted to it. I believe the wire that should have gone there is mounted directly to an auxillary feed on the pos battery terminal. I am wondering how many wires the junction block should have? Everything seems to work fine, car starts, runs, horn works, all exterior lights, radio, etc. The only issue is my "Gen" light stays on.
I can take the wire now connected directly to the pos battery terminal and run it to the junction block and then to the pos battery termibal but I dont see how that will solved my problem. I have a multi meter, what else can I check?
Damon
