anyone use this setup? its their street/strip dia clutch with 2750 lbs holding pressure.
i tried the McLeod RST , which is a dual disk setup, but it doesn't have sring loaded hubs, and i couldn't eliminate the chatter in my car.
all the while, i thought it was the lightweight flywheel, so i put the Heavy one back in, and the problem still exists...
so i'm getting rid of this mcLeod and going with either hays or centerforce...
now the only other issue is whether or not to try the 10# flywheel again... ugh, i'd hate to put it all back together and have to pull it apart a 4th time. lOL
A
