Author Topic: 69Z with 186 heads and 1.94 intake seats ????????????  (Read 7548 times)
svtrich
« on: August 04, 2009, 06:07:09 AM »
I tore my orginal DZ motor apart and ??? The guy doing my heads called and told me I had to come and check this out. This is the first time the motor has been apart so here gos.the heads are 186 castings,1.94 intake seats and 1.60 exhaust seats.strange,its gets worse.the combustion chambers are for 2.02 valves,now the kicker,it has 2.02 and 1.60 valves in the head?If I didnt see it for myself I would never believe it.could GM have screwed up when they built the engine? ???
                                         Richard
aaronz28
Re: 69Z with 186 heads and 1.94 intake seats ????????????
« Reply #1 on: August 04, 2009, 11:45:57 AM »
i'm not sure i follow... the 69 Z did have 2.02 and 1.6
so did the 67 and 68.
GM did produce the 186 heads in 1.94/1.5 versions... but not installed on Z28s.
How can you tell that it has the 2.02 combustion chamber vs the 1.94?
i'm not sure there is  difference.
thanks
Aaron
Jerry@CHP
« Reply #2 on: August 04, 2009, 11:46:10 AM »
Were the intake valve areas of the combustion chambers machined around the valve pocket?
Jerry
« Reply #3 on: August 04, 2009, 02:18:20 PM »
Here's a photo of the unshrouding cut in the chamber wall adjacent to the 2.02" intake valve in a 186 head. Are you saying that your chambers are machined like that, have 2.02" valves, but the intake seats are for 1.94" valves and it has 1.60" exhaust valves and seats?
X66 714
  • Guest
« Reply #4 on: August 04, 2009, 02:27:44 PM »
What type of head gaskets were on it? Joe
Jerry@CHP
« Reply #5 on: August 04, 2009, 03:20:03 PM »
Could have the GM 711, #5117 or the .040" Felpro.
Jerry
svtrich
« Reply #6 on: August 04, 2009, 07:15:56 PM »
it still had the steel shim
               Rich
svtrich
« Reply #7 on: August 04, 2009, 07:19:11 PM »
Jerry
Jerry,they are just like Johns pic.I wish I took some pics befor he finished the heads
Jerry@CHP
« Reply #8 on: August 05, 2009, 12:46:19 AM »
If the intakes are unshrouded, then they would be factory 2.02's unless a machine shop has done this machine process sometime in the past.
Jerry
