Author Topic: 1969 camaro non rs wipers wont park?  (Read 5800 times)
john302
« on: August 04, 2009, 04:05:59 AM »
Doing the final assembly on my l78 and the wipers wont park. They stop anywere you turn the switch off. any ideas???? thanks John  ???
Re: 1969 camaro non rs wipers wont park?
« Reply #1 on: August 04, 2009, 08:57:00 AM »
New or old motor? Inside the motor there is a parking mechanism and contacts. Usually this is the problem. It's been sometime since I've had to diagnose that issue. Your switch is good because the motor is getting juice. Check/clean all connections and grounds while your into it also.
KevinW
« Reply #2 on: August 04, 2009, 10:51:00 AM »
The parking leg of the ground circuit goes through the brass ring in the upper/center of the motor.  Once the switch is turned off, the ground then goes though the motor base, though the brass ring to the grommet metal>bolt>firewall until the parking breaker opens (internal).  Make sure you have a good ground there.
