Author Topic: Spray Washer Sand Blasting?  (Read 7613 times)
1968 Z28
« on: July 30, 2009, 05:29:42 PM »
Has anyone ever used their spray washer to sandblast? Ran across this item recently.....http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_8520_8520&issearch=2260 and was wondering if this worked very well. I am not interested in blasting a body but mainly for blasting subframe and other metal parts for rust and paint removal. Any info would be greatly appreciated.
Thanks.......
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
Pex68
Re: Spray Washer Sand Blasting?
« Reply #1 on: August 13, 2009, 11:05:57 PM »
Can't say that it would be a good idea to use this on metal parts...just think your trying to remove the rust/paint and get to bare metal and what happens to bare metal when it's wet????
Just my 2c.
Chris P
1968 Z28
« Reply #2 on: August 14, 2009, 03:49:29 AM »
Yeah....decided it would be too big a mess.
Jerry G.
tim69camaro
« Reply #3 on: August 18, 2009, 12:50:46 AM »
I purchased one after seeing this post and tested it this past weekend. I read all the reviews on the retailer's website first. I thought it worked great using the medium amber blast media the same store sells. It is much faster than my siphon air sandblaster. The water minimized the dust and flying media, but you still need eye protection. If you do not have a lot of air but already own a power washer it is an option. I dried my parts immediately with a cloth followed by compressed air. No rust and if there was a small amount metal etch/bare metal prep should take care of it. My next project is the frame for my 1967 C10. I will see if it continues to work well after longer use. So far I was impressed and if it makes it through my frame it will be well worth the $59.
For small parts a blast cabinet and air sandblaster is likely the preference to recycle the blasting media keeping the cost down.
Tim Bailey
1968 Z28
« Reply #4 on: August 18, 2009, 01:13:44 AM »
Say Tim.....what size pressure washer were you using?
Thanks in advance....
Jerry G.
tim69camaro
« Reply #5 on: August 18, 2009, 09:47:06 AM »
It is a Generac with a 5 HP Honda engine. I think it is rated at 2500 psi and 2.4 GPM.
Tim Bailey
