Author Topic: 68 carb date to motor assy which is correct  (Read 5472 times)
rare4k
« on: July 13, 2009, 05:26:45 PM »
I have a 68 car with a T0528MQ born with motor on a 06B car question is would a 861 carb be correct or is it to close ? how close can the carbs be to the trim tag date  thanks  ::)
Re: 68 carb date to motor assy which is correct
« Reply #1 on: July 14, 2009, 12:48:08 AM »
I don't see an issue - the carb was installed at the car assembly plant, not at the engine plant.
rare4k
« Reply #2 on: July 14, 2009, 04:11:31 AM »
john, how far along were the car's when the carb's were placed on them ? this carb is one week away from the trim tag thats why i'm thinking its to close and I should back it up a couple weeks to a 8- 5 something or even a 8-4 something, of the documented original one's you've seen are they as close as well thanks Phil
« Reply #3 on: July 15, 2009, 10:58:29 PM »
An 06B body would reach Chevrolet as early as the 9th of the month, or as late as the 16th; a first week of June carb works in either case.
