Author Topic: 1969 FAN INFO  (Read 11816 times)
kdka
1969 FAN INFO
« on: October 25, 2005, 10:06:44 PM »
Need to know what fan, ie number blades,etc.that was originally installed on '69 camaro 350 /350 motor/ tranny combination with out AC. Also was there a fan spacer installed originally?
Re: 1969 FAN INFO
« Reply #1 on: October 26, 2005, 07:15:14 PM »
Without A/C, L-78 or Z/28, you got a 4-blade fan and an aluminum spacer; A/C or K02 (or L-78 or Z/28) got you a 7-blade fan and clutch.
Re: 1969 FAN INFO
« Reply #2 on: October 26, 2005, 07:50:59 PM »
kdka
Re: 1969 FAN INFO
« Reply #3 on: November 05, 2005, 08:12:12 PM »
The website does explain which fan blade/radiator combination but for '69 camarosbc w/o AC,  it does not say the dimensions (inches) of the four blade fixed fan and also the aluminum spacer length has not been determined.  If someone  could tell me the correct size of both,  i would appreciate it.
thanks
kdka
