Author Topic: Correct intake for L30  (Read 14049 times)
ogbean
    • MySpace
« on: March 25, 2006, 04:18:11 AM »
What is the correct intake for the 1968 L30 327? Also my cowl date is 04A... what is my date code range to find a correct intake?
David
1968 L30 4spd ???, Rally Green, White Vinyl Top, Ivory Houndstooth Interior (716), D55 console, D91 Stripe
McKenzieDave
Re: Correct intake for L30
« Reply #1 on: March 25, 2006, 03:10:44 PM »
I have a 69 built 8D 68.  All engine cast dates are H3-H7.  About three weeks.  Dave
Steve68
« Reply #2 on: March 25, 2006, 07:15:51 PM »
Looks like the original part number was 3931575.  Used for all 68's with 4BC 327 & 350 engines except special high perf ones.  Rochester carb was used with this manifold originally too.
ogbean
    • MySpace
« Reply #3 on: March 25, 2006, 10:03:24 PM »
What is the casting # on that intake?
David
rich69rs
  • LF7/M35/Z22/Z87
« Reply #4 on: March 25, 2006, 10:14:30 PM »
I have a 68 4Bbl Qjet intake, casting number 3919803; Date code D 24 8.  References that I have state useage as '67 / '68, 327 cid 300/350 Hp, no indication in my refs about 350 cid useage.  It is available if anyone can use it.
« Last Edit: March 25, 2006, 10:18:27 PM by rich69rs »
Richard Thomas
1969 RS
« Reply #5 on: March 25, 2006, 10:27:37 PM »
Yes, the P/N 3931575 intake has a casting number of 3919803, and was used in 68 for all small block Rochester 4bbl cars.
RonM
« Reply #6 on: March 26, 2006, 01:18:48 AM »
The correct intake for the "68" L30 is casting # 3919803. However on my 07D build the intake has the casting # 3927184 with a casting date of F 22 8. That intake is for a "69" 350, but I was told Chevrolet may have started using them on late build "68's". It does have the front oil fill tube. Hope this helps, RonM.
ogbean
    • MySpace
« Reply #7 on: March 26, 2006, 04:57:52 AM »
Thanks for all the help.... anyone else got any info on what range the date code shouls be in if my cowl tag is an 04A?
David
ogbean
    • MySpace
« Reply #8 on: March 26, 2006, 05:10:43 AM »
Ok... I found two of these intakes...one dated C 4 8...and one C 5 8... would either of these be the one im looking for?
David
« Reply #9 on: March 26, 2006, 05:11:14 AM »
What's the casting date and assembly date of your block? that will get you in the ballpark. Just remember that the intake should be around the same time as the block "casting" date, but before the engine "assembly" date.
ogbean
    • MySpace
« Reply #10 on: March 26, 2006, 07:02:13 AM »
I do not have my origional block. Currently i have a 010 4 blot main 350 block with a 327 crank and pistons...not assembled yet though... my car isnt going to be #'s matching when its done... but i do want to get as many parts as close to what origionally com on the car to start...or at least a close copy of a L30/M20 should i later discover that it wasnt a real one... should i bother trying to find a correct casting and dated block and build my L30 around that.... or build it around the 010 block i have? any opinions apperciated!!!
David
