Author Topic: Gas tank date codes  (Read 446766 times)
RonM
Re: Gas tank date codes
« Reply #15 on: July 09, 2009, 09:53:42 PM »
Just to add input, I looked at the tank I removed from my 07D '68'. Same location as the others and stamped 68  52. Hope this helps, RonM.
« Reply #16 on: July 09, 2009, 10:08:48 PM »
OK, what's CRG's input on the gas tank date code debate?  Are all of the original stamps only four digits?  What does CRG believe to be the correct way to decipher the code?    ???
« Reply #17 on: July 10, 2009, 05:55:00 AM »
Well, let's compile the data. I dug out my tank and added it to the mix.
12D  68 20
02C  68 27
07D  68 52
01B  21 69
01C  22 69
05A  37 69
06A  24 69
I think the code is a running week date, starting at 01 about August and incrementing throughout the model year.
More data would help. Anyone with an early 68 or early 69 car (Aug-Dec) that can add their tank date?
« Reply #18 on: July 10, 2009, 08:46:48 AM »
12D  68 20
02C  68 27
07D  68 52
01B  21 69
01C  22 69
02D  29 69*
05A  37 69
06A  24 69
Thanks Kurt!  I knew you would have a theory.
I did a quick search over at Team Camaro.  "Gary L" has an 02D '69 Z/28 with a gas tank date code of 29 69.  I've added his data* above.
Oregonjam
  • 68 ss350
« Reply #19 on: July 10, 2009, 02:01:43 PM »
Added mine from 68. The running week theory seems to work out so far. This thread has been interesting. I never knew it was stamped. Anyone else not checked in yet that can confirm thier origonal tank?
Quote
12D  68 20
02C  68 27
07D  68 52
07D  68 53*
01B  21 69
01C  22 69
02D  29 69
05A  37 69
06A  24 69
« Last Edit: July 10, 2009, 02:15:12 PM by Oregonjam »
68 07D SS350
John
Oregonjam
  • 68 ss350
« Reply #20 on: July 10, 2009, 02:13:40 PM »
Found mine right where John Z. said, front corner, drivers side.
The date appears to be 2 4 69 with the 4 stamped upside down. Anyways the car is 06A build.
I was looking through the info again and there appears to be a discrepency with  '06A  24 69'
I think it would fall in line with the other dates we are seeing if you consider the 2 being upside down instead of the 4. Then it would read 69 42 and fit with the rest of the data. After all 69 is the same either way you look at it. ;)
68 07D SS350
John
69 skunk
« Reply #21 on: July 10, 2009, 06:10:58 PM »
That's my tank and I was wondering the same thing.
hubleyman
« Reply #22 on: July 11, 2009, 01:02:31 AM »
Here goes my first attempt at this forum.....  since you were looking for an early production '69 you made me go look (never checked before).
My 10A '69 Norwood Z/28 has a gas tank code of 6  69 (very clearly stamped).  The car has approximately 40k original miles and still has the original gas tank as far as I know...
Learn something new every day !!
Thanks for the info...
Charlie
« Reply #23 on: July 11, 2009, 02:50:04 AM »
Thanks guys for the additional data!
I didn't have one until I compiled the data. You forced me to come up with one. :)
I would agree the 06A tank either sat for a while or is misstamp.
Interesting. Since they had the year on the tank, they could just keep counting - higher than 52 wasn't a problem.
12D  68 20
02C  68 27
07D  68 52
07D  68 53
10A   6 69
01B  21 69
01C  22 69
02D  29 69
05A  37 69
06A  24 69
« Reply #24 on: July 11, 2009, 05:18:06 AM »
Thanks for figuring it out Kurt!
Pex68
« Reply #25 on: July 11, 2009, 05:47:49 AM »
Kurt you rule!!!!  Thought it was a week but didn't make sense with the Calendar year...Production year...DUH!!!!  :D
Chris P
Oregonjam
  • 68 ss350
« Reply #26 on: July 11, 2009, 02:09:20 PM »
Here is the latest list with the 06A Flipped around assuming the 2 was upside down instead. Seems to make more sense. Funny how every once in awhile a digit on a part is reversed or upside down. I never realized how common these types of issues were until reading alot of these posts.
12D  68 20
02C  68 27
07D  68 52
07D  68 53
10A   6 69
01B  21 69
01C  22 69
02D  29 69
05A  37 69
06A  42 69
68 07D SS350
John
copo
« Reply #27 on: July 12, 2009, 12:56:04 AM »
Just to add my input, I looked at the tank I removed from my 69 05E, stamped 69  41.
« Reply #28 on: July 12, 2009, 02:42:27 AM »
It was interesting to figure out. Not a lot of data, but it was Pex's 12D data was problematic and important - the wrong calendar year for a 12D car.
I tried day combinations, day week, ignoring the 12D data, etc. Took a while to break the normal dating paradigm to come up with something that made sense. Looking back, it's a duh, ....now.... :)
12D  68 20
02C  68 27
07D  68 52
07D  68 53
10A   6 69
01B  21 69
01C  22 69
02D  29 69
05A  37 69
05E  41 69
06A  42 69
tim69camaro
« Reply #29 on: July 12, 2009, 02:55:26 PM »
I checked mine yesterday. 69 12A with a gas tank date 16 69.
Tim Bailey
