Author Topic: 68 Grill nuts and bolts  (Read 18483 times)
« on: June 22, 2009, 06:18:43 AM »
I'm having a little trouble getting some original type nuts and bolts to attach the grill and mouldings to the front of my 68 Z. I'm showing a part # for the lower trim nuts in AMK's catalog as a machine threaded stamped nut.  Is this correct?  These look similar to the nuts that hold on emblems etc.  I can't tell for sure in the AIM what they look like and wondered if they were these stamped nuts and not a regular nut.
I also don't show an AMK # for the screws or nuts that hold the lower part of the grill to the valance.  The AIM part #'s are 9919303 for the screw and 3846854 for the nuts.  Anyone know what these are in AMK or can tell me the size and kind of nuts and bolts that were original?  Thanks.
PS Anyone know if the screws that hold the headlight bezels on were painted or dark phosphate?
x77-69z28
Re: 68 Grill nuts and bolts
« Reply #1 on: June 22, 2009, 03:21:29 PM »
the originals are aluminum rivets.
« Reply #2 on: June 22, 2009, 03:36:13 PM »
Non RS.
« Reply #3 on: June 23, 2009, 04:45:25 PM »
I was hoping to have this back together for a car show this weekend.  If anyone has any original bolts that they could look at or any knowledge of what they were I would really appreciate it.
x77-69z28
« Reply #4 on: June 24, 2009, 01:17:41 AM »
check your inbox.
« Reply #5 on: June 24, 2009, 08:17:42 PM »
Anyone with an untouched std grill that could check or knows what the size, type and headmark of the bolt or screw  and the nuts for attaching the bottom of the grill to the valance?
« Reply #6 on: June 28, 2009, 04:11:30 PM »
Pex68
« Reply #7 on: July 07, 2009, 06:25:06 PM »
Just wanted to link to the other thread so people can follow since we got into this discussion over there too! :)
http://www.camaros.org/forum/index.php?topic=5528.0
Chris P
« Reply #8 on: July 15, 2009, 05:14:57 PM »
Still searching.
1968 Z28
« Reply #9 on: July 16, 2009, 08:10:13 PM »
Well......I looked at my original grille hardware and the closet I can come to AMK is this.
     B-12081 Screw....Looks nearly the same as my original,  same dimensions, black phosphate, except my original has 3 bars inside the head.
     B-12250 Spring Nut ....Similar to my original, my original looks like a (U) nut, that is the (bent) and (flat) part of the nut are the same length......... whereas the AMK nut looks more like a (J) nut, the (flat) part of the nut is shorter than the (bent) part.
My car is a 68Z, 07C, NOR
Hope this helps you,
Jerry G.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
« Reply #10 on: July 16, 2009, 08:48:43 PM »
Are you saying yours was not a hex nut like the AIM shows?  Pex 68 said his was riveted.  There is a resto shop near here and they said one of theirs was put on with the spring clips too.  I also may have some info from TC soon.  I'm trying to get some pattern of how things were attached and it may change with dates.
Yes, very much so.  Thanks again.
Jerry G.
1968 Z28
« Reply #11 on: July 16, 2009, 08:54:08 PM »
Yep......no hex nut like the AIM shows..... just spring nuts and pointed hex head screws.
Jerry G.
1968 Z28
« Reply #12 on: July 17, 2009, 04:14:35 AM »
Little more info.......
I found the #9419303 screws referenced here....not for the Camaro grille but they look the same.
     http://www.paragonreproductions.com/p-350282-heater-box-y-duct-screw-kit.aspx
I found the #3846854 nuts referenced here.....not for the Camaro grille but they look close.  The set of 8 nuts are the ones that look similar to my originals.
     http://www.paragonreproductions.com/p-356156-front-grille-attaching-kit.aspx
Later.......
Jerry G.
« Reply #13 on: August 01, 2009, 07:50:54 PM »
Sonet, Does your original clip look like places A and C and just needs to be longer at B on this AMK clip?
1968 Z28
« Reply #14 on: August 02, 2009, 03:23:41 AM »
Here is a picture of my original U-Nuts with some measurements I made....
Jerry G.
