Author Topic: Points Gap and Dwell Setting for 302 Engine  (Read 11366 times)
rockphil
« on: June 08, 2009, 08:00:19 PM »
Does anybody know the proper points gap and dwell setting for a stock 69 Camaro 302 Engine using the 1111480 distributor?
Re: Points Gap and Dwell Setting for 302 Engine
« Reply #1 on: June 08, 2009, 11:16:49 PM »
The 1969 Chevrolet Chassis Service Manual states the point dwell setting should be 28-32 degrees (30 degrees preferred) for the 480 distributor.
rockphil
« Reply #2 on: June 08, 2009, 11:45:05 PM »
Thanks Paul - does the manual state what the gap should be in order to achieve the recommended dwell setting?
Stingr69
« Reply #3 on: June 09, 2009, 12:08:59 AM »
.019" is the setting. The 30° or .019" is for most all of the single points distributors that I have worked on.
-Mark.
« Reply #4 on: June 09, 2009, 01:56:10 AM »
No, there is no specification for the point gap in the '69 Chassis Service Manual for V8 engines.
I do have a 1968 Sun Electric Corporation tune-up chart for the 302 and it states the point gap should be .019" for new points and .016" for used points.
Remember, if you have a dwell meter and can set the dwell at 30 degrees then the point gap is perfect, no matter what the specification is!    :)
rockphil
« Reply #5 on: June 09, 2009, 02:16:27 AM »
Thanks Mike and Paul - I'm switching out my distributor to a rebuilt original 480 - just wanted to make sure I get it right...
glenn64vette
« Reply #6 on: June 09, 2009, 05:56:43 PM »
Back in the 60's and 70s we used to set the dwell at 26 degrees to increase rpm before point bounce.
« Reply #7 on: June 11, 2009, 04:40:01 PM »
Set the dwell FIRST, then set the timing; dwell changes affect the timing.
« Reply #8 on: June 11, 2009, 07:23:32 PM »
Correct.  As the rubbing block wears against the distributor cam lobes, dwell increases and timing retards.
