Author Topic: Cluster lens for "high beams" and "low fuel"...'67 camaro  (Read 17006 times)
SSMUNDY
  • TRIPLE BLACK 1967 CAMARO SS/RS CONVERTIBLE
Re: Cluster lens for "high beams" and "low fuel"...'67 camaro
« Reply #15 on: June 09, 2009, 02:32:51 PM »
Oh yah. Rick's used to sell used lenses for around $50.00. That's been several years ago, and the price is why I did what I did. I'm not sure if they have any or not, but you might check with them if you have'nt already done that.
Sean
heckler
« Reply #16 on: June 16, 2009, 04:39:08 AM »
P/N 6457873 used in 67 and 68.
With a Speedo and Tach.....what should the lens read in my 67?
heckler
« Reply #17 on: June 16, 2009, 04:43:42 AM »
O yeah....Originaly the speedo had OIL and BRAKE #6457871 and the fuel gauge had GEN and TEMP #6457874.
Finally, I took the lens out of the highbeam plug in the middle of the dash gauge assembly and it is "RED"?  Is that correct?  Thought it was to be blue.
Thank you so much for the help....
SSMUNDY
« Reply #18 on: June 16, 2009, 04:32:00 PM »
Red is correct.
Sean
