Author Topic: Window crank handle springs  (Read 4173 times)
jacmac
« on: June 02, 2009, 11:07:50 PM »
When taking off my door panels "deluxe" on my 69 04C I noticed their were not any window crank springs behind them. Is that unusal? Only thing behind crank were the plastic washers!Also when I took out my firewall padding I noticed that the padding itself did not go all the way to the right side of the passenger compartment.It stops just a couple of inches past the transmission tunnel. So no padding around the heater box at all! Also the padding was never "cut" it is molded on the right side! I do have AC if that matters. I post a pic but it wont post! Any help is appreciated!
jmcbeth
  • 1st and 5th Gen Camaros
Re: Window crank handle springs
« Reply #1 on: June 04, 2009, 09:09:58 PM »
This is very common. I think people generally think the springs don't help. Bot hof my 69 Z/28 are missing the springs.
John
1969 Camaro Z/28 RS
Numbers Matching
jacmac
« Reply #2 on: June 04, 2009, 10:45:36 PM »
Thank 4 your reply!!
