ccargo, yes that is used on all 67-9 Camaro's and it attaches to the driver's side rear brace for the inner fender. The mounting can be found in the AIM under Section 11-13 sheets B1 & B2, or if yours is numbered see pages 140 & 141. I have one with the rubber still attached and the clip is still in place. The clip actually attaches to the small "lip" of metal to the driver's side of the firewall, see sheet B1 upper lh corner for attaching of the rubber. I will get you some pictures later today of one off of the car, and one with it mounted. Very simple to install once you see the AIM..........RatPack.............
