Author Topic: Correct 1968 AC Compressor Identification  (Read 14908 times)
Oregonjam
  • 68 ss350
« on: May 30, 2009, 03:44:27 PM »
Does any one know where I could find a reference to the correct AC Compressor to install in my 07D Camaro?
I have one installed that needs a rebuild but am not positive that it is the correct one for the car. I would like to verify if either of these would be correct before rebuilding one.
Tag Currently has a blue stripe with the following info:
Code No: 011552
Model: 1131051
I also have another one that looks the same but it came out of a 67 Nova.
Red stripe decal with the following #s
Model: 5910738
Code: 738082392
Also, Does any one know how to decode the casting #s on the rear of the housing?
Any help is appreciated.
68 07D SS350
John
Oregonjam
  • 68 ss350
« Reply #1 on: June 02, 2009, 01:40:20 PM »
Does any one have experience restoring Air Conditioning to original in a 1968 Camaro?
68 07D SS350
John
Re: Correct 1968 AC Compressor Identification
« Reply #2 on: June 03, 2009, 02:06:21 AM »
The correct model # is 6550133.
The code # is the date code. MMDDYS - month, day, year, shift.
68Z22
« Reply #3 on: June 04, 2009, 09:33:55 AM »
The original A/C compressor on my 68 RS has the part number 6550133.
I have not had any luck with finding the correct decal for  68 compressor.
68 Z22 w/air
Mark
68 Z22 Coupe
LeMans Blue
327/275
68Z22
« Reply #4 on: June 04, 2009, 09:38:07 AM »
Does anybody know who sells the correct compressor decal for a 68 ?
Mark
68 Z22 Coupe
LeMans Blue
327/275
Oregonjam
  • 68 ss350
« Reply #5 on: June 04, 2009, 01:56:42 PM »
I recieved this from Old Air Products after inquiring about the same thing last week. They quoted a reasonable price for a rebuild and would apply the correct markings when complete. I would assume that you could order a new decal with your date code etc applied to it if you requested. Try shooting them an email and let us know what they say.
Yes, we can do a special rebuild and keep the original stickers and date code markings. Cost is $245.00, allow 2-5 weeks turn around time.
68 07D SS350
John
« Reply #6 on: June 04, 2009, 02:58:12 PM »
Make sure they use the good GM ceramic shaft seal, not the generic aftermarket carbon seal.
big iron
« Reply #7 on: June 05, 2009, 06:03:49 PM »
Kurts,
Can I assume the correct model # for a 67 is the same (6550133)?
Are all 1st gen decals red & black?
Was wondering is the 67 decal different in size since the muffler bracket goes around the body and would cover the lower red portion  of the decal.
I have seen pictures of the 67 w/bracket and the red portion of the decal is not covered. This indicates to me the decal must be longer, therefor different.
Bob
« Reply #8 on: June 06, 2009, 08:40:44 PM »
67 is the same part #, but it uses the old style sticker with orange text at the bottom.
I think it was used all year, but I'm not positive....
big iron
« Reply #9 on: June 10, 2009, 02:55:07 AM »
KertS,
Thanks for the info.
Anyone have a 5E or later build that can verify that  the old sticker w orange text at the bottom was being used at the end of the year?
What % gloss black was used on the compressor?
Bob
big iron
« Reply #10 on: October 16, 2009, 03:48:55 AM »
What % gloss black was used on the 67 AC compressor ?
Did the compressor get a final inspection OK stamp ?
68rs327conv
    • The build
« Reply #11 on: October 16, 2009, 11:57:49 AM »
Try classic auto air in Florida as they can rebuild all of your original AC components
www.classicautoair.com
68 RS Conv 327/210hp, Powerglide Factory AC
big iron
« Reply #12 on: October 16, 2009, 03:06:17 PM »
Mike,
Compressor is in good shape , just need % of gloss black and if "OK" stamp was used in 67.
« Reply #13 on: October 16, 2009, 05:06:16 PM »
Mike,
Semi-gloss black, and the "OK" stamp was used in '67.
