Author Topic: Windshield ?????  (Read 24994 times)
rare4k
Windshield ?????
« on: May 08, 2009, 03:07:01 PM »
How important is the urathane and windshield to the structure of an automobile?
MS KIM... A qualified glass technician for a local company informs me that the urathane is very important to the structure in the event of a collision.
sd1968z28
Re: Windshield ?????
« Reply #1 on: May 08, 2009, 04:29:53 PM »
very important on newer vehicles.  not so much on 1st gen camaros.
RS3SDL2MG
  • Brad
« Reply #2 on: May 08, 2009, 07:51:48 PM »
I hate that stuff , if you use it on a camaro you can't get the windshield out for upkeep work , the 3/8 rope style like they used originally are easy to get out you just take a piece of wire and cut around it then lift the glass out , simple !
1967 RS 327 (210) horse C-C ermine white 732 bright blue interior RARE 4P - DELETE
RamAirDave
    • TheMuscleCarGuys.com
« Reply #3 on: May 09, 2009, 03:40:21 AM »
The factory used a sealer similar to today's urethanes (not butyl tape), and it was important to the body's structure/rigidity.
www.TheMuscleCarGuys.com
« Reply #4 on: May 09, 2009, 02:17:51 PM »
GM never used any kind of butyl tape on any windshield or backlite; it wouldn't meet the MVSS requirements for glass retention, and didn't contribute anything to body torsional stiffness. Butyl tape is used as a short-cut installation method by some less-than-ethical glass shops, but it's nowhere near as good as urethane.
GM used Thiokol pumpable adhesive for windshields and backlites, including all 1st-Gen Camaros, which met the MVSS requirements and contributed substantially to improved body torsional and bending stiffness; Thiokol adhesive was replaced in the early 70's by pumpable urethane, the same adhesive that's still used today.
« Reply #5 on: May 09, 2009, 03:25:50 PM »
The service manual tells exactly how to cut the tip on the glass adhesive tube in order to get the correct bead.
rare4k
« Reply #6 on: May 09, 2009, 03:43:55 PM »
Automobile Windshield
Ads by Google
Windshield Replacement - 5 sec.online quotes (Mobile Serv.) Serving MD,DC,VA & DE for 46 years - www.unionautoglass.com
Glass & Mirror Experts - Providing Personalized Service & Affordable Rates Since 1980. - www.GlassAndMirrorServices.com
Best Architectural Glass - Custom Archtirectural Glass Decorative Architectural Glass - www.cosmopolitanglass.com
Lean Manufacturing - Implementing Lean Doesn't Have To Be Daunting - Free Report Explains - www.IntuitiveMfg.com/Lean-Mfg
Background
Glass is a versatile material with hundreds of applications, including windshields. Glass has a long history and was first made more than 7,000 years ago in Egypt, as early as 3,000 B.C. Glass is found in a natural state as a by-product of volcanic activity. Today, glass is manufactured from a variety of ceramic materials (main components are oxides). The main product categories are flat or float glass, container glass, cut glass, fiberglass, optical glass, and specialty glass. Automotive windshields fall into the flat glass category.
There are more than 80 companies worldwide that produce automotive glass, including windshields. Major producers in the United States include PPG, Guardian Industries Corp., and Libby-Owens Ford. According to the Department of Commerce, 25 percent of flat glass production is consumed by the automotive industry (including windows) at a total value of approximately $483 million. In Japan, 30 percent of flat glass goes to the automotive industry, valued at around $190 billion in 1989. Major Japanese flat glass manufacturers include Asahi Glass Co., Central Glass Co., and Nippon Sheet Glass Co. Little growth is expected for the flat glass industry overall in both countries. Germany has a more positive outlook, with high growth rates expected from the automotive industry.
Glass windshields first appeared around 1905 with the invention of safety glass—glass tempered (tempering is a heat treatment) to make it especially hard and resistant to shattering. This type of windshield was popular well into the middle of the century, but it was eventually replaced by windshields made of laminated glass—a multilayer unit consisting of a plastic layer surrounded by two sheets of glass. In many countries, including the U.S., auto windshields are required by law to be made of laminated glass. Laminated glass can bend slightly under impact and is less likely to shatter than normal safety glass. This quality reduces the risk of injury to the automobile's passengers.
Raw Materials
Glass is composed of numerous oxides that fuse and react together upon heating to form a glass. These include silica (SiO2), sodium oxide (Na2O), and calcium oxide (CaO). Raw materials from which these materials are derived are sand, soda ash (Na2CO3), and limestone (CaCO3). Soda ash acts as a flux; in other words, it lowers the melting point of the batch composition. Lime is added to the batch in order to improve the hardness and chemical durability of the glass. Glass used for windshields also usually contains several other oxides: potassium oxide (K2O derived from potash), magnesium oxide (MgO), and aluminum oxide (AI2O3 derived from feldspar).
The Manufacturing
Process
1 The raw materials are carefully weighed in the appropriate amounts and mixed together with a small amount of water to prevent segregation of the ingredients. Cullet (broken waste glass) is also used as a raw material.
2 Once the batch is made, it is fed to a large tank for melting using the float
The glass for automible windshields is made using the float glass process. In this method, the raw material is heated to a molten state and fed onto a bath of molten tin. The glass literally floats on top of the fin; because the fin is perfectly flat, the glass also becomes flat. From the float chamber, the glass passes on rollers through an oven (the "annealing lehr"). After exiting the lehr and cooling to room temperature, the glass is cut to the proper shape and tempered. glass process. First, the batch is heated to a molten state, and then it is fed into a tank called the float chamber, which holds a bath of molten tin. The float chamber is very large—from about 13 feet to 26.25 feet (4 to 8 meters wide and up to almost 197 feet (60 meters) long; at its entrance, the temperature of the tin is about 1,835 degrees Fahrenheit (1,000 degrees Celsius), while at the exit the tin's temperature is slightly cooler—1,115 degrees Fahrenheit (600 degrees Celsius). In the float chamber, the glass doesn't submerge into the tin but floats on top of it, moving through the tank as though on a conveyor belt. The perfectly flat surface of the tin causes the molten glass also to become flat, while the high temperatures clean the glass of impurities. The decreased temperature at the exit of the chamber allows the glass to harden enough to move into the next chamber, a furnace.
3 After the glass exits from the float chamber, rollers pick it up and feed it into a special furnace called a lehr. (If any solar coatings are desired, they are applied before the glass enters the lehr.) In this furnace, the glass is cooled gradually to about 395 degrees Fahrenheit (200 degrees Celsius); after the glass exits the lehr, it cools to room temperature. It is now very hard and strong and ready to be cut.
Cutting and tempering
4 The glass is cut into the desired dimensions using a diamond scribe—a tool with sharp metal points containing diamond dust. Diamond is used because it is harder than glass. The scribe marks a cut line into the glass, which is then broken or snapped at this line. This step is usually automated and is monitored by cameras and optoelectronic measuring systems. Next, the cut piece must be bent into shape. The sheet of glass is placed into a form or mold of metal or refractory material. The glass-filled mold is then heated in a furnace to the point where the glass sags to the shape of the mold.
5 After this shaping step, the glass must be hardened in a heating step called tempering. First, the glass is quickly heated to about 1,565 degrees Fahrenheit (850 degrees Celsius), and then it is blasted with jets of cold air. Called quenching, this process toughens the glass by putting the outer surface into compression and the inside into tension. This allows the windshield, when damaged, to break into many small pieces of glass without sharp edges. The size of the pieces can also be changed by modifying the tempering procedure so that the windshield breaks into larger pieces, allowing good vision until the wind-shield can be replaced.
A finished windshield consists of two glass layers sandwiched around a plastic interlayer. Although very thin—about .25 inch thick—such laminated glass is very strong and is less likely to shatter than normal safety glass. In the United States, windshields are required by law to be made of laminated glass.
Laminating
6 After the glass is tempered and cleaned, it goes through a laminating process. In this process, two sheets of glass are bonded together with a layer of plastic (the plastic layer goes inside the two glass sheets). The lamination takes place in an autoclave, a special oven that uses both heat and pressure to form a single, strong unit that is resistant to tearing. The plastic interlayer is often tinted to act as an ultraviolet filter. When laminated glass is broken, the broken pieces of glass remain bound to the internal tear-resistant plastic layer, and the broken sheet remains transparent. Thus, visibility remains good. Unlike traditional safety glass, laminated glass can be further processed—cut, drilled, and edge-worked, as necessary. A typical laminated windshield is very thin: each glass layer is approximately .03 inch (.76 millimeter) thick, while the plastic interlayer is approximately .098 inch (2.5 millimeters) thick.
Assembly
7 After laminating, the windshield is ready to be assembled with plastic moldings so it can be installed on the car. Known as glass encapsulation, this assembly process is usually done at the glass manufacturer. First, the peripheral section of the windshield is set in a predetermined position in a mold cavity. Next, molten plastic is injected into the mold; when it cools, it forms a plastic frame around the glass. The windshield assembly is then shipped to the car manufacturer, where it is installed in an automobile. The installation is done by direct glazing, a process that uses a polyurethane adhesive to bond the windshield and automobile body.
Quality Control
Process control includes testing of raw materials and monitoring such process variables as melting temperature, furnace atmosphere, and glass level. As the glass is formed, photoelectric devices are used to inspect for defects automatically. Other automatic devices have been developed to measure dimensions and radius of curvature after the windshield has been formed.
Safety glass used in windshields must meet certain specifications regarding properties such as chemical durability, impact resistance, and strength. Standards have been developed by the American Society for Testing of Materials (ASTM) for measuring these properties. Specifications have also been developed for windshield performance by SAE International, an organization of automotive engineers.
The Future
Despite the recent downturn in the automotive industry, long-term prospects are more optimistic. Motor vehicle production markets will be stronger than in recent years, raising demand for flat glass products such as windshields. Windshields are also increasing in size in order to accommodate newer aerodynamic designs, and thus the use of glass is increasing relative to the total surface area of vehicles. (In fact, some models are incorporating glass roofs as well.)
Such increase in glass area, in turn, has a negative impact on comfort systems, namely air conditioners, which must be able to adjust the higher interior temperatures to a comfortable level. To avoid having to use larger air conditioning systems, new glass compositions, coated glasses, and aftermarket films are being evaluated. These include angle-selective glazings that reject high-angle sun, and optical switching films that actively or passively change transmittance properties.
One recently developed film, a polymer multilayer solar control film, can also act as a deicing device. The coated plastic substrate simply replaces the laminated plastic film in conventional windshields. The film can be made in any color and can transmit up to 90 percent of the visible light. Another coating is a glaze that consists of silver coating used in combination with other metal oxide layers. This glaze can reject up to 60 percent of the total solar energy, reducing the infrared energy by 56 percent.
In addition, new types of laminated-glass windshields are being researched. A bi-layer windshield has been developed that only requires one outer sheet of glass, .08 to .16 of an inch (2-4 millimeters) thick, joined to a .254 of an inch (1 millimeter) sheet of polyurethane. The polyurethane sheet consists of two layers, one having high absorption properties and the other high surface resistance. Unique features of this bi-layer windshield include ultraviolet resistance, self-healing of scratches, weight savings, more complex shapes, increased safety due to retention of glass splinters, and anti-fog capability.
Recycling of windshield components may also become a standard practice. Though traditionally recycling has been difficult because of the plastic laminated films, one manufacturer has recently developed a cost-effective process to remove these layers. The recycled glass can be used in several applications, including glassphalt for road repair. Legislation may also speed up recycling practices, with the introduction of the Municipal Solid Waste and Hazardous Waste Research Act of 1992. This bill seeks to determine the obstacles to increased automotive components recycling and find ways to overcome these obstacles. This may eventually require using fewer resins during manufacturing or making sure these resins are compatible for recycling.
Where To Learn More
RS3SDL2MG
  • Brad
« Reply #7 on: May 09, 2009, 06:19:22 PM »
well I sure thought camaro window's were put in with the 3/8 rope , I have been doing it that way for 25 year's and will continue to do so , it just make's it so much easier to take the glass in and out of the car , and when you have to do it all by yourself any thing that make's work on these old car's easy is the way to go !!!!!
Gambitt
    • My car
« Reply #8 on: May 10, 2009, 02:50:48 PM »
It will also make it easier for the glass to come out in an accident.  Of course, we all hope that never happens, but you just never know.
Charley
« Reply #9 on: July 31, 2009, 09:26:54 PM »
This is the first I have ever heard of orig first gen windshield in Camaro's not being installed with what looks like cloth tape to me. Are we talking about different things ?
« Reply #10 on: August 01, 2009, 03:00:55 AM »
Yes.  Back in 1976 I had to reseal my front and back glass and I went to the Chevy dealer and bought two "kits".  They had tubes of Thiokol in them and you cut the tip as described to make the correct bead.
Charley
« Reply #11 on: August 01, 2009, 03:33:32 AM »
The orig cars I have seen had a cloth type seal, tape, rope or whatever you want to call it. It didn't come out of a tube.
m22mike
« Reply #12 on: August 01, 2009, 11:49:02 AM »
Charly is not blowin smoke here. On several original backlights I have removed there was some type of a woven material, along with some very tough sealant. If you look closley at some original glass sometimes you can see part of it along the inside edges. May have a differant color to it , like kind of brownish.
 John Z....help... you know what we are taking about ??
« Reply #13 on: August 01, 2009, 02:39:58 PM »
Yes, I know exactly what you're talking about, and I'll explain it (as I have several times in the "Body Shop" section on the Team Camaro site - if you do a search there using "Thiokol" as the keyword, you'll find it).
GM never used butyl tape or anything like it to install windshields or backlites. Period.
The body opening flange was coated with black silane primer using a flow-brush 30 minutes prior to installing the glass, and all the reveal molding clips were installed to the Body Shop-installed weld studs.
The glass was placed on a powered rotating fixture, inside edge up, retained by suction cups.
The glass periphery was cleaned using a solvent, dried, and a different silane primer was applied.
A fabric-reinforced self-adhesive foam rubber "dam" was extruded and applied to the glass just inboard of where the Thiokol adhesive would later be applied; the purpose of the "dam" was to contain any Thiokol "squeeze-out" so it wouldn't show from the inside past the edges of the interior garnish moldings after the glass was installed to the body.
After dam application, pumpable Thiokol adhesive (with a pyramid-shaped cross-section created by the dispensing tip) was applied adjacent to the dam, all the way around the glass.
Lower glass supports were fixture-located and screwed to the cowl, and rubber spacer blocks were glued to the opening flange. The spacer blocks set the height of the glass relative to the body to ensure a good fit of the reveal moldings.
The prepared windshield was removed from the rotating fixture, installed in the body opening, and pressed down against the rubber spacer blocks; wooden tonque depressors were used to "paddle" the Thiokol around the edges at a 45* angle from the top edge of the glass to the bottom edge of the body opening to ensure a continuous seal all the way around the glass.
Reveal moldings were installed.
That was the plant production process, and explains what is sometimes described as a "rope" being found when an original windshield is removed - the "rope" is the fabric-reinforced rubber "dam" that was applied prior to applying the Thiokol adhesive.
If you'll look in Section 4 ("Fixed Glass") in the Fisher Body Service Manual, you'll see exactly the same process for windshield replacement, except the "dam" wasn't included with the Service kit - masking tape was used instead to control "squeeze-out".
The Thiokol installation passed the Federal MVSS windshield retention tests, and contributed substantially to the body's torsional stiffness; it also helped the structure pass the roof crush test. It's illegal to replace a windshield with butyl tape, although some glass shops do it as a less-expensive short-cut method instead of doing the job right.
Charley
« Reply #14 on: August 01, 2009, 03:07:27 PM »
"A fabric-reinforced self-adhesive foam rubber "dam" was extruded" That must be what I am thinking of. What was it extruded out of ?
