Author Topic: 1967 radio options and numbers....  (Read 23334 times)
heckler
« on: May 06, 2009, 02:35:15 AM »
Does anyone have a list of radios avail. for 67 camaros?  Also, what are the model numbers?
Thanks for your help,
qwertyme77
Re: 1967 radio options and numbers....
« Reply #1 on: May 06, 2009, 05:17:04 AM »
funny you should ask. I just bought a "chevrolet radio parts catalog" P&A 5B effective sept 1973.
here is the general instructions from page 2;
GENERAL INFORMATION
The Radio Parts Catalog contains a complete alphabetical listing of all Radio
parts serviced by Chevrolet Motor Division.
The part number of each Radio set is printed on the tag that is attached to
the inside of the cover of the receiver. The part number of the Antenna may
be determined by the Radio Unit number.
The identification tag on which the Serial number is shown, is attached to
the tuner frame, inside the Radio case,directly under the cover and must be
removed for the replacement of tubes. Radios shipped from Delco Radio
Division prior to October 14, 1957, lacked identification tags, thus no Serial
numbers are available for these Radios.
By referring to the chart on page5 you will find a listing showingthe Unit
number, Antenna number, Antenna Type, Radio Set number, code number,
Year model, and description.
Information for each part is arranged in order by Codenumber, followed by
the noun description and the part number. Code numbers separated by a
hyphen indicate inclusive usage. Code numbers separated by a comma
indicate usage applicable only to the specific Code numbers listed.
When ordering Radio parts, it is only necessaryto know the Code number of
the Radio and only the Antenna number is required when ordering Antenna
parts.
EXAMPLE:
When ordering a speaker for a 985264 Radio you will find by referring
to the following chart that the Code number is 84. By referring to the
Alphabetical Index under "Speaker" which is listed under Group 9.650,
you will find Code number 84, after which part number 1219970 is
shown as the part number for the speaker.
From page 5:
Unit       Antenna        Antenna   Radio                             Code
No.           No.          Type      Set No.   Radio Type            No.   Year        Model
986198   986204   Front      986202   Push Button      120   1965      Chevelle
986316   986319   Rear      986202   Push Button      120   1965      Chevelle
                              (Spt. Cpe.
                              & Conv.)
986206   986208   Rear      986202   Push Button      120   1965      Chevelle
                              (Sedans)
986200   986204   Front      986203   AM/FM Push Button      121   1965      Chevelle
986317   986319   Rear      986203   AM/FM Push Button      121   1965      Chevelle
                              (Spt. Cpe.
                              & Conv.)
986207   986208   Rear      986203   AM/FM Push Button      121   1965      Chevelle
986112   986114   Front      986113   Manual      122   1965      Corvair
986119   986120   Rear      986113   Manual      122   1965      Corvair
986115   986114   Front      986116   Push Button      123   1965      Corvair
986121   986120   Rear      986116   Push Button      123   1965      Corvair
986117   986114   Front      986118   AM/FM Push Button      124   1965      Corvair
986112   986120   Rear      986118   AM/FM Push Button      124   1965      Corvair
986247   986309   Front      986248   Manual      125   1965      Chevy
986253   986307   Rear      986248   Manual      125   1965      Chevy
986249   986309   Front   "   986250   Push Button      126   1965      Chevy
986254   986307   Rear      986250   Push Button      126   1965      Chevy
986251   986309   Front      986252   AM/FM Push Button      127   1965      Chevy
986255   986307   Rear      986252   AM/FM Push Button      127   1965      Chevy
986280   986305   Rear      986281   AM/FM Push Button      128   1965      Corvette
986300   986301   Front      986330   Manual      129   1965      Truck
                              (exc. Tilt)
986327   985473   Front      986330   Manual      129   1965      Tilt
986340   985444   Front      986338   Manual      130   1965      Greeobrier
986341   985917   Front      986339   Manual      131   1965      G10
986539   986097   Front      986544   Manual      132   1966      Pass.
986671   986674   Rear      986544   Manual      132   1966      Pass.
986540   986097   Fron      986545   Push Button      133   1966      Pass.
986672   986674   Rear   ,   986545   Push Button      133   1966      Pass.
986541   986464   S,S. Front      986546   AM/FM Push Button      134   1966      Pass.
986524   986204   Front      986527   Manual      135   1966      Chevelle
986662   986667   Rear      986527   Manual      135   1966      Chevelle
986525   986204   Front      986528   Push Button      136   1966      Chevelle
986664   986667   Rear      986528   Push Button      136   1966      Chevelle
986526   986463   S.S. Front      986529   AM/FM Push Button      137   1966      Chevelle
986112   986114   Front      986113   Manual      122   1966      Corvair
986683   986685   Rear      986113   Manual      122   1966      Corvair
986115   986114   Front      986116   Push Button      123   1966      Corvair
986684   986685   Rear      986116   Push Button      123   1966      Corvair
986480   986462   S.S. Front      986118   AM/FM Push Button      124   1966      Corvair
986516   986519   Front      986521   Manual      138   1966      Chevy
986680   986682   Rear      986521   Manual      138   1966      Chevy
986517   986519   Front      986522   Push Button      139   1966      Chevy
986681   986682   Rear      986522   Push Button      139   1966      Chevy
9864}6   986305   Rear (Elect.)      986281   Push Button      128   1966      Corvette
                              (327)
986478   986305   Rear (Elect.)      986281   Push Button      128   1966      Corvette
                              (427)
986770   985917   Front      986769   Manual      140   1966      G10
986772   986301   Front      986771   Manual      141   1966      Truck
                              (exc. Tilt)
986773   985473   Front      986771   Manual      141   1966-67      Tilt
986860   986925   Front      986863   Manual      142   1967-69      Corvair
986923   986926   Rear      986863   Manual      142   1967      Corvair
986861   986925   Front      986864   Push Button      14:3""   1967-69      Corvair
986924   986926   Rear      986864   Push Button      143   1967      Corvair
986862   986927   Front      986865   AM/FM Push Button      144   1967-69      Corvair
986834   986819   Front      986835   Manual      145   1967      Camaro
986855   986825   Rear      986835   Manual      145   1967      Camaro
986848   986819   Front      986823   Push Button      146   1967      Camaro
986820   986825   Rear      986823   Push Button      146   1967      Camara
986821   986822   Front      986824   AM/FM Push Button      147   1967      Camaro
986866   986900   Front      986868   Manual      148   1967      Chevy
986903   986901   Rear      986868   Manual   .   148   1967      Chevy
986867   986900   Front      986869   Push Button      149   1967      Chevy
986904   986901   Rear      986869   Push Button      149   1967      Chevy
986849   986902   Front      986852   Manual      150   1967      Chevelle
986905   987039   Rear      986852   Manual      150   1967   -   Chevelle
986850   986902   Front      986853   Push Button      151   1967      Chevelle
986908   987039   Rear      986853   Push Button      151   1967      Chevelle
I'm sorry about the columns but I couldn't get my scans to attach to the post and i had to cut and paste.
hope this helps.
heckler
« Reply #2 on: May 06, 2009, 11:02:07 PM »
Model # on side of radio is 7305572
What this mean?
« Reply #3 on: May 06, 2009, 11:12:30 PM »
Mike, a 7305572 is a 1968 Pontiac Firebird AM Radio.
heckler
« Reply #4 on: May 07, 2009, 12:06:38 AM »
qwertyme77
« Reply #5 on: May 07, 2009, 12:11:51 AM »
so i guess the part numbers i posted aren't the gm part numbers?  then what are they?
« Reply #6 on: May 07, 2009, 12:16:39 AM »
They're part numbers, but for Chevrolet cars and trucks. He had a 68 Pontiac Firebird radio so it's different than what you have posted.
heckler
« Reply #7 on: May 07, 2009, 12:22:13 AM »
This proves more research was needed before I made this purchase.  The seller advertised it as 67-68 radio and I trusted his description.
Now I'm stuck.
Mike  >:(
qwertyme77
« Reply #8 on: May 07, 2009, 12:34:40 AM »
but his part number (as most gm part numbers from that era) are 7 digits long. what i have are only 6 digits long.
Mark
« Reply #9 on: May 07, 2009, 02:19:27 AM »
There are only 4 different radios available for the 67 Camaros, and one of those I don't think I've ever seen.
986823 Camaro AM pushbutton radio
986835 Camaro AM manual (no pushbuttons - haven't seen this one)
986824 Camaro AM/FM mono pushbutton radio
7301001 67/68 Camaro Tape Stereo (mounts under dash on tunnel or front of console)
Thats it for 67s.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
qwertyme77
« Reply #10 on: May 07, 2009, 02:25:26 AM »
thank you. i guess my numbers are correct then!
Mark
« Reply #11 on: May 07, 2009, 02:59:03 AM »
Numbers are right, they're Delco numbers not GM service part numbers.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
sebastien
« Reply #12 on: May 07, 2009, 05:20:42 AM »
Quote
aside from the part number how do you tell a firebird radio from a Camaro?
Sebastien 68  327 rag top
Mark
« Reply #13 on: May 07, 2009, 10:40:48 AM »
I think the lens is blue tinted on a firebird radio, and green on a Camaro.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
heckler
« Reply #14 on: May 12, 2009, 01:17:50 AM »
How do I tell the model I have if the outside sticker is gone?
Only thing on outside is embossed in metal casing:
FMC62      18750
