Author Topic: Rally wheel dating  (Read 26352 times)
bc69
Re: Rally wheel dating
« Reply #15 on: December 22, 2014, 02:03:03 AM »
Thanks for the reply Paul. But unless I'm missing something this link doesn't really answer my question. Other that saying some wheels do not have app code it doesn't say that some do not have date codes. I haven't looked on the inside of the wheel but mine do not have a date code on the outside of the wheel. It does have the DG right next to stem on all 5 of the wheels though.
Brad
RSSS
« Reply #16 on: December 22, 2014, 02:15:36 AM »
Sorry Brad, 1967 rally wheels are not dated by the valve stem.  There is a stamped date on the inside of the wheel, but you will need to remove the tire to see it.
bc69
« Reply #17 on: December 22, 2014, 02:21:06 AM »
Was hoping that was the case. I will pull one and check it out soon. Do they use the same format on the DG's? Or is it the different one as they  mentioned?
Brad
RSSS
« Reply #18 on: December 22, 2014, 02:23:42 AM »
It will look like this...
bc69
« Reply #19 on: December 22, 2014, 02:38:03 AM »
Can you define code?
Brad
RSSS
« Reply #20 on: December 22, 2014, 03:06:49 AM »
Brad, the above photo is for reference only.  It is from a 1967 Corvette "DC" 15" x 6" rally wheel.  It is dated 2 67 for February 1967.
bc69
« Reply #21 on: December 22, 2014, 03:09:54 AM »
Gotcha! I'll pull one. Thanks for filling me in. When I pull it I'll post back what I find. Thanks Paul.
Brad
RSSS
Petes L48
« Reply #22 on: December 22, 2014, 04:53:02 PM »
There was a DG wheel discussion on this forum back in September:
http://www.camaros.org/forum/index.php?topic=12536.0
I've never seen a 67 model year DG wheel with a year stamp of 66, so I'm wondering if they just started that year & month stamp in January 1967?
bc69
« Reply #23 on: December 22, 2014, 08:09:33 PM »
Just pulled one of mine and cleaned about 49 years dirt off and no stamping at all on backside.
Brad
RSSS
« Reply #24 on: December 22, 2014, 08:27:23 PM »
Pete might be on to something, Brad.  Was your Camaro built in '66?
bc69
« Reply #25 on: December 22, 2014, 08:34:31 PM »
Yep it's a 12c car
Brad
RSSS
« Reply #26 on: December 23, 2014, 07:37:30 PM »
Kelsey-Hayes has been stamping the wheel size and month and year date code on the inside of the rim since 1951; Chevrolet wheels didn't get the type code and dating stamped on the outside of the rim adjacent to the valve stem until 1968.
bc69
« Reply #27 on: December 23, 2014, 11:06:03 PM »
Well these have the DG at the stem and there is nothing on inboard.
All 5 have the DG on the same spot but I didn't look at the inboard side on the other 4 yet.
Are you saying that they are not orig?
Brad
RSSS
« Reply #28 on: December 24, 2014, 03:25:32 PM »
<< Are you saying that they are not orig? >>
I don't know, but every Kelsey-Hayes wheel I've ever seen has the size, month and year date, K-H logo, and Tire & Rim Association certification logo stamped on the inside, under the tire.
« Reply #29 on: December 24, 2014, 04:19:49 PM »
04D
