Author Topic: 15 X 6 DC Rally Wheels  (Read 17045 times)
MyRed67
  • SZZLN 67
« on: April 20, 2009, 04:54:29 AM »
  I have done some research on the 15 X 6 Rally Wheels.  I pretty sure the correct 15 X 6 Rally's for a '67 Z/28 were coded DF.   I have 3, not a matched set, that are coded DC as follows:   K17  12   (stem)  7   DC
        K18  4    (stem)  24  DC
        K18  8    (stem)  20  DC
From research I have done I believe that the  first Wheel codes out,  Dec. 7 -67.   #2 Wheel I believe is Apr. 24 -68.   #3 Wheel Aug. 20 -68.    I have found information that the 15 X 6  DC code was used on Corvettes in '66 & '67, but I believe that Corvette went to 15 X 8 Wheels in '68, which these wheels code out to be.    Anybody have any ideas?   Thanks!
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
Re: 15 X 6 DC Rally Wheels
« Reply #1 on: April 20, 2009, 06:02:17 AM »
The "DC" rally wheel was used in 1968 on the full size Chevrolet passenger car.
« Reply #2 on: April 20, 2009, 02:46:25 PM »
The "DC" rally wheel was the standard wheel on the '67 Corvette (in addition to full-size cars and station wagons with disc brakes); the ones you show are service replacements made in '77, '74, and '68. The '67 "DC" wheels weren't rim-dated. '68 Corvettes used 7" AG rallys, and '69-'82 used 8" AZ rallys.
MyRed67
  • SZZLN 67
« Reply #3 on: April 21, 2009, 07:45:37 AM »
OK, I hope this works I am going to try to attach a photo.   I did some closer searching on the outside of the rim (between the beads) and found these stampings.   Would be on the back half of center, nearer the bead.  Would service replacements have had this Kelsey Hayes logo on them?   Also, you can see fairly clearly that this wheel is stamped with a 12 & a 67, this is the wheel I thought was a Dec. 67 wheel.   I can also make out a 4 & a 68 on the wheel that I thought was an Apr. 68.  The third wheel also has this same logo with a small A  & a 8   stamped under the 15 X 6 JK.   the A & the 8  are stamped at various angles compared to the straight line of the 15 X 6 JK.   Do these stampings add any clarity to the date codes?   ThanX!
1967 Camaro  LOS  11A
« Reply #4 on: April 21, 2009, 03:15:32 PM »
The "12" and "67" say that wheel was made in December, 1967, and the others were made in '68; didn't come off a '67 Corvette, as the model year ended in July, 1967. Most likely they're off a '68-'70 passenger car with disc brakes, as the '67 Corvette 'DC" wheels only had the "DC" stamped adjacent to the valve stem hole (no visible dates on the outside of the rim).
tar6569
« Reply #5 on: April 21, 2009, 03:50:29 PM »
Yup those are Impala wheels.  If you will not be using them, I am looking for DC rally wheels for my 68 and 69 Impalas, which all have disc brakes.
Warren
Warren
1964-1970 fullsize Chevrolet research
MyRed67
  • SZZLN 67
« Reply #6 on: April 22, 2009, 01:31:13 AM »
Sorry Warren, I do plan to use them.   My plan is to build my car to a Z/28 "tribute/resto-mod".    And I plan to use 2 of these on the front, and 1 in the trunk.   I plan to use 15 X 8's on the rear.
1967 Camaro  LOS  11A
« Reply #7 on: April 22, 2009, 06:50:19 AM »
FYI, the "DC" wheel and the "DF" wheel have different offsets.
MyRed67
  • SZZLN 67
« Reply #8 on: April 22, 2009, 08:04:07 PM »
 Hi Paul, it was my understanding that the JK code at the end of the 15 X 6 JK, was the rim profile.   And from info. I have the DF wheel also has the JK profile.   I understand that the offset or backspacing could be different, do you know how much?   FYI; I'm assuming you looked at my reply above as to (I intend to use these wheels) and how I intend to build this car.   At this point I'm not planning on putting original Dual Piston Brake Calipers on the car(I'm planning to use an available kit), will this make any difference?   I have maintained all along that I don't intend to pass this off as an original Z/28, one look at the Cowl tag anyone with any Camaro knowlege will know this car was built too early to be a original Z.   Thanks for your help!     Mike
1967 Camaro  LOS  11A
« Reply #9 on: April 22, 2009, 10:29:34 PM »
I understand that the offset or backspacing could be different, do you know how much?  Thanks for your help!     Mike
Mike -
The '68 "DC" wheel has a offset of .06"
The '68 "DF" wheel has a offset of .50"
MyRed67
  • SZZLN 67
« Reply #10 on: April 23, 2009, 03:15:38 AM »
  Thanks Paul, I understand what you are saying about offset.   The back of the center of the wheel (where it mounts to the hub), is almost "on center" .06 isn't much.    Whereas .50 is a half inch.   I guess I understand "backspacing" better than I do offset, in sense of #'s.   So is it .44" more backspace?  Or .44" less backspace?    Thanks again.    Mike
1967 Camaro  LOS  11A
« Reply #11 on: April 24, 2009, 12:24:13 AM »
It's 0.44" more backspace. Offset is the dimension between the plane of the centerline of the rim and the plane of the wheel mounting surface; Positive offset means the wheel mounting surface is closer to the outboard side of the rim, and negative offset means the wheel mounting surface is closer to the inboard side of the rim. The illustration below shows the relationships of wheel measurements.
MyRed67
  • SZZLN 67
« Reply #12 on: April 24, 2009, 04:01:27 AM »
Thanks again, Paul!   You've been a lot of help.   Thanks for the link!
1967 Camaro  LOS  11A
