Author Topic: Need 3953692 water pump  (Read 11834 times)
McKenzieDave
« on: March 18, 2006, 10:22:40 PM »
Needing a dated water pump from early H of 68.  All of my engine cast dates are H4 to H7.  Car build is 8D.  Engine build is 0816.  I know this is not an easy one to find as this is extremely early 1969 production and this was a new water pump.  Thanks,  Dave
rich69rs
  • LF7/M35/Z22/Z87
Re: Need 3953692 water pump
« Reply #1 on: March 19, 2006, 07:45:05 AM »
Dave:
Hope you find your water pump.  When I found the correct 69 327 cid for my ride, it still had the original 3953692 water pump, K 8 8 date code for Nov 22 engine build.
In my searching around over the years, I do have a spare GM water pump.  It is #3927170, date coded E 17 71.  I realize that you are going for an accurate date coded rebuild and that this pump probably isn't what you are looking for - however, it is available.
Additionally, according to page 224 of Chevrolet by the Numbers: 1965-1969, it states the following about #3927170: This water pump was used interchangeably with #3953692.  #3953692 saw extensive usage, #3927170 saw very little usage
Good luck
Richard
Richard Thomas
1969 RS
KevinW
« Reply #2 on: March 19, 2006, 02:26:44 PM »
Rich, just to clarify.  The 170 was only used on Tonowanda assembled small blocks.  So if your block code starts with a T, you can use it, if it starts with a V, then no.
McKenzieDave
« Reply #3 on: March 19, 2006, 07:27:43 PM »
Thanks for the replies, I do have one from 70 as a last resort.  Dave
clarkedog
« Reply #4 on: March 19, 2006, 10:46:39 PM »
Im guessing this is not what your looking for but I have a 3953682   A151 what that date is I do not know ,Scott
GaryL
  • Marilyn and me
« Reply #5 on: March 20, 2006, 03:27:13 PM »
Try Heartbeat City. He has a ton of water pumps with dates all over the place.
Gary
McKenzieDave
« Reply #6 on: March 21, 2006, 05:36:14 AM »
Thanks, I've seen a lot of his NOS stuff on E-bay.  Dave
