Author Topic: which Posi ID tag is correct for '67 - 12 bolt rear end  (Read 6139 times)
MyRed67
  • SZZLN 67
« on: April 17, 2009, 02:06:59 AM »
Which ID tag is correct for a '67 - 12 bolt rear?    I have a Red quarter circle tag that fits on the fill level / sight plug.   But I also see a little metal tag that fastens on one of the rear cover bolts also listed for '67 Camaro.   Which is correct?    Or should it have both??   If the little metal tag is correct, which bolt should it be fastened on?    I appreciate any help, Thanks!
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
sd1968z28
Re: which Posi ID tag is correct for '67 - 12 bolt rear end
« Reply #1 on: April 17, 2009, 01:53:22 PM »
red tag for 12 bolt.  metal tag for 10 bolt.
Fast67velleN2O
« Reply #2 on: April 25, 2009, 12:19:43 AM »
"Positraction Fluid Only" red tag on fill plug.  NOT the "limited slip only" red tag.
