Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Restoration
honing a engine cylinder
« previous
next »
Print
Pages: [
1
Author
Topic: honing a engine cylinder (Read 4969 times)
fireZ
Hero Member
on:
April 07, 2009, 11:57:21 PM »
How much material is removed when honing a cylinder ? Can standard pistons be used after honing?
Tweet
Logged
1968 Z28 LA Built
LIC # RPO Z28
CNorton
Member
Re: honing a engine cylinder
Reply #1 on:
April 08, 2009, 02:25:23 AM »
The honing process (when correctly done) removes a minnimal amount of material and produces a cylinder wall that is straight (same diameter at all points from top to bottom). The purpose of the hone is to achieve a particular finish texture to promote piston ring seal, not necessarily to increase the bore size. Reusing the same pistons is not an impossibililty but the practicality of that practice it will depend on the piston-to-wall clearance that exists after the honing process is complete. Refer to the piston manufacturer's recommendations regarding piston-to-wall clearance before deciding.
Logged
Tinkerr
Member
Reply #2 on:
April 08, 2009, 02:45:04 AM »
The honing process is better left to someone with experience, not for the novice. When done properly you get good results, improperly, the rings don't seal, to much material removed, your buying pistons and having the engine bored.
Logged
fireZ
Hero Member
Reply #3 on:
April 08, 2009, 01:03:37 PM »
Thanks guys I plan on taking the block to a reputable engine shop and have them look at it.
Logged
1968 Z28 LA Built
LIC # RPO Z28
Print
Pages: [
1
« previous
next »
Restoration
