Poll
69 L48 (SS350) blocks
2 bolt main?
2 (13.3%)
4 bolt main?
13 (86.7%)
Total Members Voted: 14
Author Topic: 69 L48 (SS350) - 2 or 4 bolt mains?  (Read 13449 times)
« on: March 17, 2006, 04:52:23 AM »
I wanted to know if others have seen 1969 L48 engines with 2 bolt mains. Most have 4 bolts, but some are 2 bolts. How common is this??
Reposting as a poll. :)
Re: 69 L48 (SS350) - 2 or 4 bolt mains?
« Reply #1 on: March 17, 2006, 06:30:22 PM »
Kurt, the L48 350/300 used in the '69 Corvettes (base engine) used the 3932386 (early), 3956618 (mid-year), and 3970010 (late) blocks, and all were 4-bolts. From then on, they used the 010 block for all 350 applications thru 1979, and starting in '71 the base versions were 2-bolts and the optional versions were 4-bolts.
« Reply #2 on: March 19, 2006, 06:56:51 AM »
Problem is that in practice, that's not true for all L48's. I have a L48 block and it's a 2 bolt main and I've heard of others. Most were 4 bolts, but 2 bolts were used sometimes. Trying to put a finger on how common 'sometimes' is.
And relatedly, trying to figure out if there was a difference in the LM1 and L48 shortblocks. Components are the same, so they should be the same except LM1's seemed to get more 2 bolt main blocks.
waynechipman
« Reply #3 on: April 04, 2006, 01:35:00 AM »
Had a LM1 with four barrel and it was two bolt and was a 388 block, car also had the lower sitting engine frame mounts.
cib12
« Reply #4 on: January 16, 2007, 02:10:07 AM »
for the record i purchased a new 69ss350- had it for 90k miles- (late production) it had 4 bolt mains
Jerry@CHP
« Reply #5 on: January 16, 2007, 02:07:42 PM »
In 1971, my best friends's parents had a 1969 Impala, 350-300.  I helped install a new rear main seal in this vehicle.  This engine was a two bolt block.  When we started on the job, we were thinking it should be a four bolt block.  I have no clue what the BD is as this car is long gone.
Jerry
rich69rs
  • LF7/M35/Z22/Z87
« Reply #6 on: January 16, 2007, 08:23:25 PM »
.....also, a lot of 3932386 blocks were 2 bolt 327 cid applications - base Camaro in '69 for example - I have one in my RS.   It seems perfectly plausible that this same block could have been used for either base 327 or base 350 builds.....and then just to confuse things a little more, there is the 4 bolt version of this block which sometimes got stamped DZ.
Although this engine is not original to my car, it was original to VIN: # 124379N551248
Engine Numbers:
Casting: 3932386
Casting Date: J 31 8
Engine Pad: V1122FJ (69 Camaro, 327, 3 spd manual)
« Last Edit: January 16, 2007, 08:35:10 PM by rich69rs »
Richard Thomas
1969 RS
click
    • Our 69 RS
« Reply #7 on: January 19, 2007, 05:42:34 PM »
My 10C of 68 built LM1 camaro (69) has the ...388 block with 4 bolt mains. :)
hotrod68
  • almost finished
« Reply #8 on: January 20, 2007, 04:36:12 AM »
Before all this stuff started getting documented, the general rule from '68-'69 and early '70s was if it was a 350 4-barrel with a 4-speed it had 4-bolt mains, but the automatic 350 4-barrels were generally 2-bolt, excepting, of course, the '70 and later LT-1s. I saw enough 350s torn down around this time to say it could be true--every 4-speed car I saw had 4-bolt mains, Camaro or not. Co-incidence? Who knows. Just throwing another Wive's Tale out there...chuckle
