Author Topic: 69 Front Brake Line Clips  (Read 11425 times)
69z28302
« on: April 04, 2009, 12:10:41 AM »
I was just comparing the finish on some clips that I got from a suppiler vs the originals I took off my car. The original on the right look more like a transparent blue to me . Does anyone know what finsh was used on the originals?
Thanks CGR
Re: 69 Front Brake Line Clips
« Reply #1 on: April 04, 2009, 02:33:14 PM »
The coating on the originals was more of a "dye" than paint, and the coloration varied widely; some of the reproductions appear to be "painted".
69z28302
« Reply #2 on: April 04, 2009, 08:24:09 PM »
Thanks John for the info.
GaryL
  • Marilyn and me
« Reply #3 on: April 22, 2009, 12:09:48 PM »
Thanks CGR
The images do not show up. Would you mind posting them again? Thanks.
Gary
« Reply #4 on: April 22, 2009, 05:07:14 PM »
Images show up fine for me...
GaryL
  • Marilyn and me
« Reply #5 on: April 25, 2009, 01:44:40 AM »
Now I see them.
Gary
« Reply #6 on: May 02, 2009, 04:00:55 PM »
Does the color look similiar to machinist layout dye-
Dykem Blue?
69z28302
« Reply #7 on: August 29, 2009, 10:17:07 PM »
Dykem Blue?
Yes more of a transparent blue.
« Reply #8 on: September 08, 2009, 04:14:21 AM »
Exactly ----
I pulled my clips off of my pace car and they were so heavily coated in body shop undercoating gunk that when placed in a mild  (Solvent 140) tank the grime came off exposing the tranlucent Blue dye coloring..Nothing like the clips in the left side of the pictures above.
Ultimatly what I did was include the clips in my plating batch (Bright Zinc) and hung them from a wire and mist sprayed them with Dykem Blue layout Blue,,,they look very close to as found.
GaryL
  • Marilyn and me
« Reply #9 on: September 09, 2009, 03:14:44 AM »
I did something similiar. I had them clear zinc plated then used DupliColor #T155 light blue metallic as thin as possible. They came pretty good.
Gary
RamAirDave
    • TheMuscleCarGuys.com
« Reply #10 on: September 09, 2009, 04:58:16 AM »
The clip finishes vary.   From the iridescent-type blue to a robin's egg paint/color.
Repo vs. Orig.  Repos on the outer edges, the black split-clips are repainted orignals, the rest are untouched originals.
www.TheMuscleCarGuys.com
m22mike
« Reply #11 on: September 17, 2009, 07:01:19 PM »
Some of the last junked up clamps I got from the Chi Neez resto places are powder coated blue. Kind of looks like the one pictured ? ( IMO powder coating should be reserved for lawnmowers... :P
 I soaked them in MEK in a closed jar and removed the power coating. Underneeth the clamps appeared to have been made from galvanized sheet stock. Not bad looking. I used my modeling airbrush and dusted them with a light coat of over reduced Testors model paint I mixed up.
 Blue layout ink is even better. And the airbrush is the bomb ! Try it.
OE clamps I have re plated in clear Cad and re dye as above.
