Another quick tell tale sign without knowing any of the numbers is the 2 bolt mains.
Nope, you would need to know that the block casting
number was 3970010 for that to be true. There were other '69 Camaro small block engines (307cid, 327cid) with different block casting
numbers that had two bolt main caps.
