Author Topic: Coil Bracket finish  (Read 11279 times)
gro51
  • 68 SS/RS 350
Coil Bracket finish
« on: March 14, 2009, 12:54:57 PM »
What is the correct finish for the coil bracket?   (68 350)
Joe
Schodack, NY
'68 SS/RS 350, M21, 3:73, Rallye Green, Black Deluxe Interior
Re: Coil Bracket finish
« Reply #1 on: March 14, 2009, 10:45:02 PM »
Silver cadium dichromate.
« Reply #2 on: March 15, 2009, 12:29:53 AM »
Here's a list to cover more than your request:
http://www.67z28.com/finishes.htm
gro51
  • 68 SS/RS 350
« Reply #3 on: March 15, 2009, 12:44:13 AM »
Thanks.  Where can I get that done?  Is it something I can do myself?
Joe
Schodack, NY
« Reply #4 on: March 15, 2009, 01:33:58 AM »
i've never done it but I will. I work in any medium when required. Two sources I found are:
 http://www.caswellplating.com/
http://www.brushplate.com/brushplating.htm
Just punch in Silver cadium dichromate. You'll get more info. I'm sure someone on here has done it before.
« Reply #5 on: March 19, 2009, 06:11:37 AM »
I have never seen a DiChromate treated Cad coil bracket.
di·chro·mate
Pronunciation: \(ˌ)dī-ˈkrō-ˌmāt, ˈdī-krō-\
Function: noun
Etymology: International Scientific Vocabulary
Date: circa 1864
: a usually orange to red chromium salt containing the anion Cr2O72− <dichromate of potassium> —called also bichromate
The DiChro treatment of a Cad or Zinc plated part turns the part the Yellow color,,,,,or Burns i brown with excessive duration
I believe that list incorrectly uses the term.
Go ahead and purchase the Cadwell system, It works well if you can manufactue a power supply, properly prep your parts, handle the Chem.
Otherwise find a jobber or industrial plater who will handle hobby parts.
Coil bracket should be Bright Cad, I swear some of them even look galvanized?
« Reply #6 on: March 19, 2009, 06:46:29 PM »
Zinc-plated - no dichromate wash.
« Reply #7 on: March 19, 2009, 06:59:44 PM »
Thanks John. Apparently the finishes list I posted above is not the be-all end-all. Now I wonder what else is wrong on the list.
GaryL
  • Marilyn and me
« Reply #8 on: March 20, 2009, 01:48:52 PM »
Since we are talking coil brackets, how are the non-cowl and cowl hood brackets identified?
Gary
GaryL
  • Marilyn and me
« Reply #9 on: March 23, 2009, 01:06:43 AM »
Bump.
Gary
« Reply #10 on: March 24, 2009, 04:44:30 PM »
The coil bracket used with ZL2 tilts the coil back at about a 30-35 degree angle to clear the O.D. of the larger air cleaner base; the standard bracket tilts the coil at around a 15-20 degree angle.
GaryL
  • Marilyn and me
« Reply #11 on: March 25, 2009, 03:57:03 AM »
Thanks.
Gary
