Author Topic: which oil pump for a 69 302  (Read 5788 times)
svtrich
« on: March 10, 2009, 02:53:38 PM »
which oil pump should I use.
       thanks again Richard ;D
Re: which oil pump for a 69 302
« Reply #1 on: March 10, 2009, 03:08:18 PM »
Use the Melling Select #10553 (photo below) - don't use the new Melling M55 with the diagonal ribs on the casting (photo below) - the new casting is lighter/thinner, and failures have been reported in performance applications.
CVKUEBER
« Reply #2 on: March 10, 2009, 06:27:20 PM »
You could also use GM 302 service replacement pump part# 12555884. Still available from your local GM dealer.
