Author Topic: Venezuela's Camaros....  (Read 35664 times)
jacmac
Re: Venezuela's Camaros....
« Reply #15 on: May 03, 2009, 09:30:38 PM »
Hello I just found this web site! Thought I new alot about 69 camaros,but after reading many previous post,its apparent to me that I dont!Anyway I had to comment on this particular post! I travel to the Philippines as often as possible & thought I would have to give up my passion for old muscle cars if I retire there, Maybe I wont! Thanks for all the great info!
angel_jo
  • Venezuelan Camaro 69 RS 350
    • Spanish american car forum
« Reply #16 on: May 27, 2009, 08:59:32 AM »
Hello! I'm new in this forum
I was searching information about Venezuelan camaros, and I found this post.
I'm owner of a Venezuelan Camaro, I bought it in Venezuela last year, but I live in Spain.
I'm trying to decode the TRIM TAG, but it's imposible, I don't know how to decode a lot of numbers!
This is my VIN:
12437JC113124
And this is the TRIM TAG:
            BODY BY FISHER
ST   12437JC113124      BDY
TR   715  926-161107    PNT
I'll try to put some photos
The VIN is easy, J=9 C= Caracas
I decode the interior code: 715= blue standar interior
But... what's this? 926-161107
Can you help me to decode?
Thanks!
angel_jo
« Reply #17 on: May 27, 2009, 09:06:04 AM »
This is my trim tag:
angel_jo
« Reply #18 on: May 27, 2009, 09:25:03 AM »
And this is my Venezuelan Camaro
« Reply #19 on: May 29, 2009, 01:34:00 AM »
Nice car! And not a common sight in Spain!
You have the highest VIN I have seen on a Caracas Camaro.
Do you know if the drivetrain is original? Do you have any of the stamped codes from the engine, trans, or axle?
926-161107 is a Dupont paint code. I can't ID what color that indicates but does not look like a production 69 formula.
angel_jo
« Reply #20 on: May 29, 2009, 07:39:57 AM »
Thank you very much for your answer Kurt!!
Yes, it's very difficult to see an american car in Spain. I know about 10 Camaros 1st gen in our roads...
Really? The highest? Guauu!!
I'll check all the codes and I'll post here, so you can get all the information about the car.
I think everything is original
I'm trying to search this dupont code, but don't find anything :( Can you help me?
Watching the old property title of the last venezuelan owner, I saw that the color was GREY, it could be?
Thanks a lot!!
angel_jo
« Reply #21 on: May 29, 2009, 08:46:48 AM »
The engine is a 350, I have to check if it is the LM1 350ci/255HP  V8 4BC, or the L65 350ci/250HP  V8 2BC.
Where can I see the engine code? Can I check it without removing anything?
The rear axle, I think it is the original. I have the codes:
The axle stamp is: BN 0605G2
BN=ratio 3.55, size, 12 bolts, type=N (non positraction)
The axle casting date is E239
E=may
23=day 23
9=1969
I'll try to get the engine number and the trans code
« Reply #22 on: May 30, 2009, 02:35:01 AM »
The engine code is stamped on the pad under the alternator. It will be a L65, too late for a LM1.
http://www.camaros.org/drivetrain.shtml#PadStamps
12 bolt - wouldn't have expected that.
Disc brakes?
Thanks!
angel_jo
« Reply #23 on: May 30, 2009, 08:14:26 AM »
Hi Kurt! Yes, front disc brakes, with power brakes. Power steering, AC, power windows...
angel_jo
« Reply #24 on: May 30, 2009, 08:49:42 AM »
I have bad news :(
My engine isn't the original :(
I checked the engine code and I get this:
GM 3970010 (a 350 block)
V1221TBM
C97141328
The suffix TBM in not a 69 valid suffix!! I think it is a '79 engine, could be? :(
PURESS
« Reply #25 on: May 30, 2009, 01:07:40 PM »
LOOKS LIKE YOUR ENGINE CAME FROM 1979 CONV. VAN
angel_jo
« Reply #26 on: June 01, 2009, 03:51:24 PM »
Conv. van? What model is it?
Thanks!
PURESS
« Reply #28 on: June 02, 2009, 01:12:00 AM »
Thanks!
That's a full-size Chevy Van, built at the Lordstown, Ohio van plant.
« Reply #29 on: June 03, 2009, 02:11:46 AM »
Wow, that's pretty loaded. More loaded than I would have expected.
Console and gauges?
1 or 2 fuel lines?
Any #'s off of the transmission?
« Last Edit: June 03, 2009, 02:30:37 AM by KurtS »
