Author Topic: '67 fuel tank question.  (Read 7754 times)
Brandan
  • 1969 Camaro SS 396 X-66 M22
    • 1969 Camaro 396 SS M22
« on: February 25, 2009, 03:26:41 PM »
If I remember correctly, the assembly manual shows that the filler tube is attached to the tank by being soldered.  My body guy says it is clamped on both ends with the rubber sleeve.  When I did my '69 tank I remembered that the tank came with the filler neck attached.....
What is the correct way to mount the filler neck and be correct?
Brandan-
Check out the 1969 ride!!!
http://www.cardomain.com/ride/676916/1
Check out the new project!!!
http://www.cardomain.com/ride/2960049
CVKUEBER
Re: '67 fuel tank question.
« Reply #1 on: February 25, 2009, 04:21:27 PM »
67-68 models used a filler neck that bolted to the rear body panel and used a 2 in. id. hose to connect the tank to filler neck. 69 filler necks were soldered to the tank.
NED
« Reply #2 on: February 25, 2009, 05:11:06 PM »
Your body man is correct on that one! separate filler neck with rubber sleeve and clamps holding it together.   Bill C.
Bill
67Z Bench seat
69JL8 Burnish Brown
67 camaro modified ls1,6 speed, 9 "rear
Brandan
« Reply #3 on: February 26, 2009, 05:18:19 PM »
thanks..... i will give it a try....
CVKUEBER
« Reply #4 on: February 26, 2009, 06:42:47 PM »
Both the filler neck and hose are still available from GM. part numbers 3893113 and 3834073 respectivley.
Brandan
« Reply #5 on: February 28, 2009, 11:55:14 PM »
got em thanks......
