Author Topic: engine decoding- non-original Smallblock  (Read 8824 times)
Jesper
« on: February 22, 2009, 06:57:35 PM »
hi,
foud these numbers on the engine block of my 69īcamaro cab. Tried to decode, but didīnt find any match. Can anyone help?
T0222CJD
H
11N546532
Thanks in advance,
Jesper Denmeark
rich69rs
  • LF7/M35/Z22/Z87
Re: engine decoding- non-original Smallblock
« Reply #1 on: February 22, 2009, 07:29:58 PM »
hi,
T0222CJD
H
11N546532
Thanks in advance,
Jesper Denmeark
One on line source that I checked decodes the CJD suffix as:  1971 350 cid; 270 HP, 4BBl; TH350 trans. A or F body application.
T = Tonawanda engine
0222 = Feb 22
CJD = 1971, 350 Hp
The first "1" in the partial VIN# 11N546532 doesn't fit.  Could it be a "7" instead of a "1"?   If it is a "7", then the partial VIN is would be:  71N546532; which would indicate that the engine was originally in a 1971 Camaro; manufactured at Norwood, with VIN sequence #546532.  Since it  was obviaoulsy a V8, the complete VIN for the original car would have been:  124871N546532.  In 1971, the 3rd digit in the VIN (4 in this case) would indicate a V8, the 5th and 6th numbers (71) would have indicated the year.  The first VIN produced in Norwood for 1971 was 500000, so #546532 would have been the 46,532 1971 unit built at Norwood
Above based on the assumtion that the first "1" is really a "7" and not a "1".  If it is a "1", I'll have to defer to others more knowledgeable.
« Last Edit: February 22, 2009, 07:46:05 PM by rich69rs »
Richard Thomas
1969 RS
Jesper
« Reply #2 on: February 22, 2009, 07:39:06 PM »
Hi Richard,
thanks a lot, but could this be correct? It donīt seem like a 350-horsepower-engine...
/Jesper
PANTHER-BUFF
« Reply #3 on: February 22, 2009, 08:07:22 PM »
CJD is a 270hp engine
Danny
« Reply #4 on: February 23, 2009, 08:06:40 PM »
Actually, it fits fine - the '71 VIN derivative used 9 digits. The first "1" is for Chevrolet, and the second "1" is for 1971. It's a '71 Camaro engine.
Jesper
« Reply #5 on: February 25, 2009, 07:27:14 PM »
Hi both of you.
I will check up on sunday- mayby shoot a photo of the numbers to be sure.
Again- thanks a lot for some very valuable information.
/Jesper
Denmark
Jesper
« Reply #6 on: March 01, 2009, 07:59:57 PM »
Hi again,
i shot this photo today.
Anyone with a good guess, wheter it actually is a 71īCamaro engine?
Best regards from Denmark (where it soon will be spring, mmmm...)
/Jesper
« Reply #7 on: March 01, 2009, 09:22:36 PM »
CJD is a 1971 Full Size, Nova, Chevelle and Camaro 350/270 engine. I can't make out the VIN, so I can't tell you which car it came from, although it appears to be 11N.... so if that's correct, then yes, it's from a 1971 Camaro.
Jesper
« Reply #8 on: March 02, 2009, 07:37:28 PM »
Hi Ed,
"11N" appears to be correct, so it should be a 71īCamaro 350/270hp.
Thanks a lot for your "investigations" in this matter. !
Best regards
/Jesper
