Author Topic: Hub caps and steel wheels?  (Read 12701 times)
BowtieSweden
« on: February 07, 2009, 08:49:25 PM »
If you want to replace, in my case, 14" SS-wheels.
What is the most appropriate option, for hubcaps and rims?
Manufacturers and size, pictures if possible?
The car is a -69 SS350 X55
GUS
Camaro SS Conv. -69
Impala SS Conv. -67
Camaro SS Coupe -12
Bjv69ss
Re: Hub caps and steel wheels?
« Reply #1 on: February 08, 2009, 01:38:38 PM »
I will take some photos and post them later, I don't have my camera here but in my opinion I'd put a set of Torque Thrust wheels with redlines on you car... very nostalgic!  You'll find a photo of them in any car mag or just google.
1969 Fathom Green
SS 350 Coupe
71 Impala Sport Coupe
BowtieSweden
« Reply #2 on: February 08, 2009, 04:51:19 PM »
Yes, TT with redline is nice, but it's more common than my SS-wheels.
And TT, with or without redline, is 8 out of 10 cars.
No, I will not put that on the car.
I'm looking for original SteelWheels with a set of HubCaps.
My questions is, what or which is the right set of hubcaps for my car?
GUS
Camaro SS Conv. -69
Impala SS Conv. -67
Camaro SS Coupe -12
tom
    • Discount Internet Services
« Reply #3 on: February 08, 2009, 07:05:45 PM »
Are you looking for something that could have been original?
69 X11 Z21 L14 glide
o
Bjv69ss
« Reply #4 on: February 08, 2009, 07:09:28 PM »
1969 Fathom Green
SS 350 Coupe
hgger69
  • Hugger orange rules!
    • Håkans Motorsida
« Reply #5 on: February 09, 2009, 01:10:59 PM »
GUS
Tjen mannen!
Du skall väl ha samma som jag fast med en snobbring, om du skall vara korrekt! Tror dock fälgen skall vara silverlackad på SS men ej säker!
Hakan from Sweden
www.hakansmotorsida.com
hgger69
    • Håkans Motorsida
« Reply #6 on: February 09, 2009, 02:05:57 PM »
Here are some more pics of what I meant:
The rims looks silver to me!? :-\
Hakan from Sweden
Bjv69ss
« Reply #7 on: February 09, 2009, 11:30:33 PM »
Those are trim rings with dogdish caps
1969 Fathom Green
SS 350 Coupe
« Reply #8 on: February 10, 2009, 04:13:58 AM »
RPO P06 - trim rings. Don't see them too often. Hides most of the wheel color.
hgger69
    • Håkans Motorsida
« Reply #9 on: February 10, 2009, 08:36:57 AM »
Cause it is, that were what I meant or...?  ???
But Kurt, is this the same trim rings used with the Rally Wheels??
Hakan from Sweden
BowtieSweden
« Reply #10 on: February 13, 2009, 09:22:32 PM »
Hi and Hej
Yes this looks nice.
But as someone asked, is it same trimring as on RallyWheels / SS-Wheels?
And what kind of rims is it, 14 or 15"?
Håkan, var fick du tag på dina kapslar och fälgar?
GUS
Camaro SS Conv. -69
Impala SS Conv. -67
Camaro SS Coupe -12
hgger69
    • Håkans Motorsida
« Reply #11 on: February 14, 2009, 07:50:37 AM »
Hi and Hej
GUS
Hi & hej!
Fälgarna är alltid 14" men däremot e mina 14x6" då jag har en basmodell, X44. På en SS tror jag det skall vara 14x7"....och det var jag som frågade om det var samma ringar Rally Wheels eller SS ?
Jag fick tag i fägarna via Camaroskroten och Björn. De korrekta GM från rätt fabrik men inte exakt match.number men gjorda för skivbroms som jag har. Kapslarna hade jag tur att hitta mycket fina beggade i E-tuna hos en Camarofantast. Dessa dog dish nytillverkas numera och kan köpas via bl.a. Classics Industries! ...dock inte samma känsla som fina beggade tycker jag! :)
Hakan from Sweden
« Reply #12 on: February 15, 2009, 03:09:23 AM »
I'm not sure. I've never really dealt with the P06 rings and I don't see (though it's probably there) the P06 in the parts book.
tom
« Reply #13 on: February 15, 2009, 01:29:46 PM »
I found in my interchange book a listing for 14" trim rings. Part number is: 9796919. Book says for 14 inch 68-70 chevelle, Camaro, Nova with SS wheels. Same book shows SS wheels as 14 x 7 with 13/32 offset. I know the ss wheel in not the plain steel, but this is the only listing in my book for trim rings on anything other than the Rallye wheels.
o
