Author Topic: '68 Power steering conversion  (Read 5226 times)
paulsstuff
« on: February 04, 2009, 03:10:38 PM »
 I recently picked up  a power steering box, pump, hoses, and brackets off a '67 Camaro and want to install on my manual steering '68. Should this simply be a bolt-in installation or are there components that differ? I know the pitman arm and steering arm are different and have aquired them new. But I'm not sure if the p/s cars used the same column as manual steering.
 Any help or info would be greatly appreciated. Thanks
mrdetails
Re: '68 Power steering conversion
« Reply #1 on: February 04, 2009, 03:18:44 PM »
Column is the same.
Good Luck
Sam
paulsstuff
« Reply #2 on: February 04, 2009, 03:22:09 PM »
 Fantastic. Thanks Sam.
CVKUEBER
« Reply #3 on: February 04, 2009, 04:11:41 PM »
The rag joint between the column and gear box are different for manual and power steering.
