Author Topic: 67 SS350 carb spring  (Read 10613 times)
SMoon67
    • My online garage - restoration pics
« on: January 29, 2009, 06:53:10 PM »
Could someone please post a picture or diagram, or direct me to one, that shows the correct carb return spring setup for the 67 SS 350.  Thanks.
67 RS/SS 350 4 spd Marina Blue
1988 IROC-Z Convertible
1957 Chevy Belair
1940 Chevy Cabover
Re: 67 SS350 carb spring
« Reply #1 on: January 29, 2009, 10:26:59 PM »
There's a diagram of this in the '67 AIM.
SMoon67
« Reply #2 on: January 29, 2009, 11:37:11 PM »
I have a copy but didn't see this in there.  I'll try again.
1957 Chevy Belair
1940 Chevy Cabover
« Reply #3 on: January 30, 2009, 12:17:30 AM »
I don't have a '67 AIM, but my '68 AIM says the L48 carburetor assembles the same as the L30.  Try looking under UPC L30, Sheet A4 in your '67 AIM (that's where the information you need, but for the '68 model year only, is in the '68 AIM).
SMoon67
« Reply #4 on: January 31, 2009, 12:30:05 PM »
Thanks Paul.  I saw the diagram but it doesn't add up based on the spring that I have that's supposed to be the right one.  I'd still like to see a picture of a stock setup.
1957 Chevy Belair
1940 Chevy Cabover
kforce
« Reply #5 on: January 31, 2009, 11:19:12 PM »
1967 RS/SS 350 - PG - Sierra Fawn - Black Vinyl - Gold Deluxe
1974 Z/28 - 4-speed - Silver (with those ridiculous stripes)  Black Interior
1998 Z/28 - 6-speed - Bright green - Convertible
SMoon67
« Reply #6 on: February 01, 2009, 02:30:35 AM »
Thanks.  That helps a lot.  That looks like the spring I have.  The assembly manual showed it connecting by the coil which would not work with that spring.
1957 Chevy Belair
1940 Chevy Cabover
SMoon67
« Reply #7 on: February 01, 2009, 01:17:08 PM »
This is the only picture I could find that shows the setup that's in the assembly manual.  I have no way of knowing if this is how this particular car was set up originally.
1957 Chevy Belair
1940 Chevy Cabover
kforce
« Reply #8 on: February 01, 2009, 07:59:40 PM »
You can get a similar aftermarket return spring bracket at Summit or on eBay.
As far as I can find the 2 barrels got the coil bracket setup from the factory. The four barrels got the tower with a hook.
Look on page 338 UPC M35 of the AIM. It is the only view I could find.
Don't know if the tower is for the automatic trans kick-down rod to clear or if there was a difference with m/t like in the picture..
« Last Edit: February 01, 2009, 08:32:07 PM by kforce »
SMoon67
« Reply #9 on: February 02, 2009, 12:24:03 AM »
I saw the setup from the picture in the AIM but not the one you're talking about.  I'll check that out when I get home.
1957 Chevy Belair
1940 Chevy Cabover
kforce
« Reply #10 on: February 02, 2009, 11:25:32 PM »
The orange wire tower in the picture is incorrect. Hear is a picture of the correct tower (repro from HeartBeatCity) for the SB Camaro.
http://i256.photobucket.com/albums/hh163/GFORCEMASTER/1967%20Camaro/1dc4eb0a.jpg
« Last Edit: February 02, 2009, 11:48:21 PM by kforce »
