Author Topic: did 68 MO blocks have 2 or 4 bolt main caps?  (Read 7623 times)
jsg1010z
« on: January 28, 2009, 03:42:35 AM »
I have searched the forum for the answer to this, but no luck... thanks for your help!
JohnKY
Re: did 68 MO blocks have 2 or 4 bolt main caps?
« Reply #1 on: January 28, 2009, 04:01:53 AM »
2 bolt.
Jerry@CHP
« Reply #2 on: January 28, 2009, 04:35:03 AM »
2-bolt with windage tray.
Jerry
hotrod68
  • almost finished
« Reply #3 on: January 28, 2009, 05:26:16 AM »
As a general rule, no '68 small-blocks had 4-bolt caps, 302 or otherwise. The 4-bolt blocks didn't appear until 1969. Hope this helps.
mjbake
« Reply #4 on: February 03, 2009, 06:06:57 PM »
OK I'm still learning. What is MO?
67 L30/M20
Convertible
Gramps69Z
  • 69 X33 D80
« Reply #5 on: February 03, 2009, 09:13:13 PM »
 MO would be the engine code stamped on the block for 67 and 68 302's.
Captain John Wykoff
« Reply #6 on: February 03, 2009, 09:19:21 PM »
In 1967 "MO" was the engine application suffix code for 302s without smog.     ;)
In 1968 all 302s where stamped "MO".
Gramps69Z
  • 69 X33 D80
« Reply #7 on: February 03, 2009, 09:31:20 PM »
MP would be for smog on 67's.
Thanks Paul,
Captain John Wykoff
